Author Topic: mame input help  (Read 2078 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
mame input help
« on: February 10, 2011, 10:37:25 pm »
I've set up MAME before but am now having trouble with it. I have the Input (general) set for my panel but the Input(This Game) controls seem to override it. How can I set it to only read from the general input?
VanillaGorilla
  • Coin detected in pocket
Re: mame input help
« Reply #1 on: February 10, 2011, 11:22:05 pm »
throw away the cfg file for the game. Input(this game) always takes precedence, if defined, on a game by game basis.
« Last Edit: February 10, 2011, 11:23:37 pm by VanillaGorilla »
methodical
Re: mame input help
« Reply #2 on: February 10, 2011, 11:26:13 pm »
k, problem is that is seems to create a cfg file for each game when it is run. Is there a way to turn that off?
VanillaGorilla
Re: mame input help
« Reply #3 on: February 10, 2011, 11:37:19 pm »
nope. just dont change the input map for the game and it will use the defaults.
methodical
Re: mame input help
« Reply #4 on: February 11, 2011, 12:13:58 am »
Tried deleting all of the cfg files that it made for games, and it's still doing the same thing. It creates a cfg file for the game with the default mame input keys and runs that.
VanillaGorilla
Re: mame input help
« Reply #5 on: February 16, 2011, 05:37:46 pm »
Isn't that what you wanted? It now defaults to the 'defaults', unless you override them individually.
methodical
Re: mame input help
« Reply #6 on: February 17, 2011, 06:57:54 pm »
it was defaulting to MAME's original keyset instead of what keys I set it to, but I did eventually get it fixed starting with your suggestion. Thanks :-)
Jefferson
  • Last login:January 14, 2024, 08:50:59 pm
Re: mame input help
« Reply #7 on: June 07, 2011, 01:29:03 am »
Hey I came upon this old post and I've got a weird variant problem... I used cfg magician to make a bunch of cocktail-DIP-switch-flipped cfg files, so I can't delete those.
My issue started with the P1 and P2 start buttons (They're to be programmed to u360 joy button 4 on Joy1 and Joy2)
I figured maybe I could go back into CFG magician and make another cocktail list, this time also configuring the start keys, but those are some of the only undefinable keys in CFG magician.
As far as I know, cfg magician creates NEW cfg files that you're supposed to place in the mame folder system, you dont edit the existing cfg files.
Is there another way to program P1 and P2 start mame-wide?  Or am I going to have to either A.) flip all cocktail switches to ON manually or B.) Define P1 and P2 start in all games manually?
