Author Topic: Wells Gardner K7191 chassis -horizontal line-  (Read 2899 times)
Maarten
  • Last login:October 08, 2015, 04:21:32 pm
« on: February 07, 2011, 09:18:01 am »
Hello
I have problem with WG monitor K7000 series.
last week, my image was very shaky. image/no image.
but for now, i have a black image with only horizontal white line in the middle of the screen.
i have a vertical synch issue.
can someone tell me what components (vertical ic, resistors) can be wrong. i do not think the vertical IC, but i was thinking about bad soldering.
or failing res. i seen it before with WG K7000 series.
txs for help guys.
« Last Edit: February 07, 2011, 10:26:26 am by Maarten »
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Wells Gardner K7191 chassis -vertical line-
« Reply #1 on: February 07, 2011, 10:18:19 am »
Vertical line with the monitor horizontally oriented (as in a regular TV)? That would indicate a problem with the horiz yoke deflection coil. If its a vertical line with the tube vertically oriented its a vertical deflection problem (either the yoke coil connection or the deflection IC).
Pls clarify. I'd check for cracked solder first tho....
Maarten
Re: Wells Gardner K7191 chassis -horizontal line-
« Reply #2 on: February 07, 2011, 10:29:59 am »
big mistake from my side
the monitor is indeed mounted Horizontaly in cabinet, like a mortal kombat cab
and white line is also situated horizontaly.
best regards
Maarten
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 07, 2011, 11:22:07 am »
Agreed.... scour the entire chassis for bad solder joints first, as there are several common spots that could cause this. Namely around the vertical IC and the yoke headers pins.
