Author Topic: Arcade VGA, old arcade monitors and dmame, talk amoungst yourselfs...  (Read 1602 times)
ntjedi
  • Last login:June 12, 2009, 04:02:25 pm
  • Who wants to be a firetruck?
This may be a dumb quesion but here it goes....
I am running dmame with advmenu for the front end in 98 dos.  I have a old 25" Sega arcade monitor and the ArcadeVGA card.  The monitor is fairly sesitive on the vertical frequency so I ran the avres utility to create the ini files for each game.  After I did this most of the games do work (although now they have a picture of their monitor bezel around them) but, for example, Ms Pacman is still rolling.  I guess it was my understanding that the avres utility was supposed to set the resolutions so they will all work on a 60Hz monitor.
I think I am having a major brain fart and any help would be greatly appreciated! :P
"Genius? Nothing! Sticking to it is the genius! ... I've failed my way to success."
--Thomas Edison
ntjedi
Re:Arcade VGA, old arcade monitors and dmame, talk amoungst yourselfs...
« Reply #1 on: August 21, 2003, 01:29:21 pm »
FYI, I am running a search on the boards but I also thought I would ask the question.
Just dont want to give the wrong impression.
--Thomas Edison
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« Reply #2 on: August 21, 2003, 01:45:45 pm »
Take out the bezel artwork in mame.ini  Your forcing it to do 800x600 which is interlaced and your monitor cannot handle it.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: August 21, 2003, 03:18:29 pm »
some stuff here I've had teh same problem before... (well i didn't enable artwork... )
hmph... I dunno.  I still haven't totally solved it myself.
*shrug*
rampy
ntjedi
« Reply #4 on: August 21, 2003, 03:52:02 pm »
I'll fix the mame.ini tonight.  Other than that I am also going to try something that Pyronious suggested and use a custome ArcadeVGA.txt file for the avres program.
I'll let y'all know how it works out for me.  I am slowly getting the MameTiki complete.  Now if I can just stop playing games long enough for me to mount my controllers!
--Thomas Edison
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #5 on: August 23, 2003, 03:49:34 am »
im feeling ferklempt talk amongst yourselves
ill give you a topic
-Linda Richman
