Author Topic: NFL Blitz Emulated  (Read 2644 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
NFL Blitz Emulated
« on: August 20, 2003, 08:24:28 pm »
Anyone know if NFL Blitz is emulated?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:NFL Blitz Emulated
« Reply #1 on: August 20, 2003, 08:30:17 pm »
it is via epsxe and (i think) pj64, and there is a pc version.
It's all about the Pentiums
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #2 on: August 20, 2003, 08:35:36 pm »
I have the pc version installed in my cabs.
A place called purplus.com has it for like $5.
One setback - I could not get it to re-map the keys to the standard MAME/IPAC layout so I ended up remapping my controls around Blitz.
Re-mapping helped a lot with ZINC, too so it's OK.
bsoder52
« Reply #3 on: August 20, 2003, 09:09:48 pm »
My copy is on it's way!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: August 21, 2003, 12:12:01 am »
Yeah, why get emulated when it can run natively.  And hte PC version is essentially the the arcade version, doesn't have support for a n64 card but oh well.
StephenH
« Reply #5 on: August 21, 2003, 11:16:38 pm »
Aaron Giles has a WIP driver for it.   You will need a very, very fast CPU as its main CPU to be emulated is a 150MHZ R7000.
Aaron Claims about 4-5GHZ minimum for the Dynarec core, or 7GHZ without the dynarec core :-(.
See www.aarongiles.com for a WIP screenshot.
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #6 on: August 23, 2003, 12:17:48 am »
the original ran on a 3dfx voodoo 1 card so it ran on a pc in the arcade sorta
SirPoonga
  • Puck'em Up
« Reply #7 on: August 23, 2003, 01:38:37 am »
Modified 3DFX I believe, can't port it to use PC 3DFX driver directly I believe.
BombProofPlane
« Reply #8 on: August 23, 2003, 03:44:40 am »
well not exactly the voodoo 1 was stock its just the main processor was mips not x86
bsoder52
« Reply #9 on: August 25, 2003, 08:43:38 pm »
I got it and it looks sweet!  But I haven't been able to figure out what the keyboard controls are.  any help?
Bill_S
  • aka buzzdalf
« Reply #10 on: August 25, 2003, 09:03:22 pm »
If I remember right you need to go in and modify the controls.  In order to do that you have to us the default keyboard controls to navigate in and customize them.
OK,  I got my manual out.  The default controls are on page 4 of the little jewel case manual.  Using those controls go into arcade, then options, then system options, then controllers.  Page 10 in the manual tells how to actually change them.
Warning - I could not get the game to let me map any controls to the CTRL key.  Like I said above, I ended up re-mapping my IPAC around keys I was able to get Blitz to use, keeping it as close to the MAME default as possible.
« Last Edit: August 25, 2003, 09:04:16 pm by Bill_S »
bsoder52
« Reply #11 on: August 25, 2003, 09:44:56 pm »
Ok,
Thanks for the additional info.  The only problem is that mine didn't come with a cover or instructions.
CAn ya pretty please help me out?
When I ran it it looked awesome!
I can't wait to play!
Bill_S
  • aka buzzdalf
« Reply #12 on: August 26, 2003, 07:23:06 am »
I could scan in the pages you need from the instructions.
Tonight after work, that is.
bsoder52
« Reply #13 on: August 26, 2003, 02:14:21 pm »
You are the man!
That would be awesome!
Could you email them to me?
Or do you need a fax #>?
Bill_S
  • aka buzzdalf
« Reply #14 on: August 27, 2003, 07:16:41 am »
I had a rough night working last night.  I didn't even turn on my PC (a real rarity).
Sorry about that.  At any rate, I just scanned the instructions in.
Here's links to the files:
http://web.thewavz.com/buzz/blitz1.jpg
http://web.thewavz.com/buzz/blitz2.jpg
Let me know if you have any problems downloading them.
