Author Topic: AimTrak firmware with recoil output  (Read 3890 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: February 04, 2011, 04:35:40 pm »
If anyone is experimenting with recoil, I have firmware available which outputs a 40ms pulse on pin 5 of the header when the trigger is pulled while on screen.
I think the best way of driving the solenoid is to use a mosfet. Use a 1K resistor in series with the gate. Dont forget to connect a diode across the coil to remove back-EMF.
andy@ultimarc.com
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
Re: AimTrak firmware with recoil output
« Reply #1 on: March 05, 2011, 02:02:15 am »
by any chance, would you happen to have a wiring diagram???  are you going to incorparate the solenoid into your guns and sell them?  ;D
« Last Edit: March 05, 2011, 02:04:49 am by Savannan »
Drakin
  • Last login:December 10, 2022, 12:51:42 pm
« Reply #2 on: March 05, 2011, 12:56:05 pm »
I'm interested...point me to where the firmware is...Thanks Andy
Drakin
loppydog
  • Last login:April 18, 2012, 02:51:39 pm
« Reply #3 on: March 05, 2011, 04:02:34 pm »
that would have been handy when I was setting up my Aimtraks!  But here is how I decided to do mine:
Code: [Select]
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/111309-simple-one-shot.html#post910451
