Author Topic: quieting crt whine  (Read 4506 times)
newmanfamilyvlogs
    • Newman Family Vlogs
quieting crt whine
« on: February 02, 2011, 09:27:20 pm »
Can the high pitched whine from a crt be minimized? Where does it actually originate from?
Re: quieting crt whine
« Reply #1 on: February 02, 2011, 10:43:57 pm »
Your ears are too sensitive, expose yourself to loud music for extended periods of time.  ;)
I can hear a high pitch buzzing/whining from many electronic devices that everyone else in my family can't seem to hear.
As for your questions, I have no idea. Sorry.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: February 03, 2011, 09:10:22 am »
the horizontal output stage is the typical offender .
"singing" components may be located with a gentle nudge with an insulated probe while listening for any change
in sound . installing,wedges,shims,glue to the offending part  MIGHT provide a cure.
using NTSC , the operative frequency is 15.734Khz.
this is within the human auditory range .  scan freqs above 20Khz are unheard.
as men age, the high end reception drops off considerably.
as such, i am no longer able to hear a 15Khz tone .
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« Reply #3 on: February 03, 2011, 09:25:13 am »
Some monitors, like the WG7203 have a heavy guage wire which makes a couple of turns around part of the FBT.  I found that this sometimes is the source of a high pitched squeal.  This "noise" can be reduced or eliminated by repositioning the wire coils with an insulated screwdriver.
« Last Edit: February 03, 2011, 09:34:22 am by kardenm »
In theory, there is no difference between theory and practice, but in practice.....there is!!
newmanfamilyvlogs
« Reply #4 on: February 03, 2011, 09:30:25 am »
My wife notices the sound much more than I do. I suspect I already have a bit of frequency loss due to the previously suggested application of loud noises in my earlier years.
I'll have to poke around in there with something non-conductive and see what I can find. I suppose next will be looking for some material to dampen the noise with. Maybe I can pack in some kind of acoustic insulation around the entire chassis.
qrz
« Reply #5 on: February 03, 2011, 09:53:32 am »
caution, insulation will likely interfere with ventilation.
and no surprise the XYL is more sensitive to the sound.
newmanfamilyvlogs
« Reply #6 on: February 03, 2011, 10:37:54 am »
I'll keep the ventilation in mind if I do anything.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #7 on: February 04, 2011, 08:18:03 pm »
It depends on the type of sound....
-Banned-
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #8 on: February 04, 2011, 08:53:35 pm »
Its just the horiz scan freq that yer hearing. It bugs some ppl, others not so much. Really nothing you can do about it....
