Author Topic: Depth of TV area?  (Read 17060 times)
britinva
  • Last login:April 04, 2011, 08:53:26 am
Depth of TV area?
« on: January 31, 2011, 03:46:20 pm »
Re: Project Arcade II plans.
Can anyone out there confirm the min depth between the back edge of O and the rear panel M?
Bassically trying to work out if a TV thats 20" deep will fit without modificatins to the standard design.
Thanks,
Mark
Rando
Re: Depth of TV area?
« Reply #1 on: January 31, 2011, 04:17:04 pm »
Thanks,
Mark
For the Ultimate Arcade II plans, I called the company a couple of weeks ago with this same question.  Per the rep (I haven't built mine yet so cannot verify 100%) the dimensions INSIDE are as follows:
Width - 27"
Height - 24.5"
Deep - 20.5"
So based on that the 20" is there, but I imagine it will be tight.  Luck.
britinva
« Reply #2 on: January 31, 2011, 04:43:23 pm »
Thanks - I think there are potentially some way's the sneak a bit extra room...... like a thinner hardboard back panel, and thinner O & P.
I guess only way to find out is to start building - but few weeks before I start mine.
AtomSmasher
    • Atomic-Train
« Reply #3 on: January 31, 2011, 05:34:58 pm »
Does the new Project Arcade book follow the Ultimate Arcade II plans?  Because the original book didn't.
britinva
« Reply #4 on: January 31, 2011, 07:50:36 pm »
Yes, it does seem to follow the Ultimate Arcade II plans.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
« Reply #5 on: January 31, 2011, 08:25:10 pm »
The new book uses the Ultimate Arcade II plans, which affects chapters 2 and 6. However, if you prefer the original LuSiD plans, the companion CD has the original chapters 2 and 6 with those plans. :)
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
