Author Topic: can I use an mpeg instead of an avi for startup movie?  (Read 3274 times)
zipdaman12
  • Last login:February 26, 2016, 07:43:30 am
« on: January 23, 2011, 02:05:09 pm »
I have an mpeg that I like and want to use it as startup movie.  all mala will allow me to select are avi files?  Can I use an mpeg' if yes than how?
Thanks.
Zip
TopJimmyCooks
Re: can I use an mpeg instead of an avi for startup movie?
« Reply #1 on: February 06, 2011, 10:33:23 am »
I think the Mala wiki confirmed AVI only for startup movies somewhere, but I can't find the exact reference.  I just dl'd a free mpg to avi converter and used it on that short version arcade84 intro vid, which worked.  That video doesn't look good at my screen resolution but it's a placeholder until I get something I like better.  HTH.
fallacy
  • Last login:March 11, 2025, 01:20:39 am
« Reply #2 on: February 15, 2011, 03:27:55 pm »
step 1. download a free .avi converter
step 2. .....
step 3. profit
loadman
  • Moderator
    • MaLa
« Reply #3 on: March 06, 2011, 01:00:54 am »
Hi,
The Video Engine in MaLa supports playing/displaying the following file types:
*.mp*;*.vro;*.avi;*.wav;*.asf;*.wmv;*.vob;*.avs;*.mov;*.divx;*.mid;*.mp4;*.mts;*.3gp;*.swf;*.m2v;*.mkv;*.flv;*.jpg;*.bmp;*.gif
I just played a .mpg and it played it fine
The issue with the current version as the file choosing filter has not been updated to show files other than .avi
I will fix this for the next version but you can easily get around this by either
1) -Refer attached pic- change the serach criteria to *.* in the open dialogue
OR
2) Manually editing the file/path in mala.ini
« Last Edit: March 06, 2011, 01:22:23 am by loadman »
loadman
  • Moderator
    • MaLa
« Reply #4 on: March 13, 2011, 04:51:55 am »
You can now select it with MaLa 1.74
