Author Topic: What value are these POTs?  (Read 1460 times)
WhereEaglesDare
    • My HomePage
« on: January 17, 2011, 08:33:32 pm »
This is a control board off of a WG 25K7194.
They all ended up getting broken and I need replacements.
Thanks.
MonMotha
Re: What value are these POTs?
« Reply #1 on: January 17, 2011, 09:52:36 pm »
There's usually a number somewhere on the pot (look around the "collar" opposite the leads).  It will be something like 102.
The first two digits are the "significant" digits.  These are the first two numbers in the value.
The last digit is the "exponent".  This is the number of zeros after the "significant" digits.  The resulting value is in ohms.
So, for my example of "102", that's a 1000ohm or 1k ohm (k = kilo = 1000) pot.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 18, 2011, 12:35:13 am »
You have a k7000 series monitor and Bob Roberts sells a complete kit of pots for the k7000 remote board:
http://homearcade.org/BBBB/k7remote.html
http://homearcade.org/BBBB/parts.html#pots
Contrast: 10k
Black Level: 2k
Vert position: 25k
Vert size: 200 ohm
Vert hold: 500k
Horiz position: 500 ohm
« Last Edit: January 18, 2011, 01:09:01 am by Ken Layton »
