Author Topic: Booting into FE with XP Embedded  (Read 2326 times)
Rok
  • Last login:June 11, 2012, 09:02:36 pm
« on: January 14, 2011, 12:05:59 pm »
Has anyone been able to do this?
As far as I have been able to find, XP Embedded requires you to input a password/log in to an account. Has anyone been able to bypass this?
Re: Booting into FE with XP Embedded
« Reply #1 on: January 14, 2011, 01:09:19 pm »
Hey Rok,
I don't have any specific experiance with XP embedded, but I am assuming you already tried changing the settings in the userpasswords2 control?
If it doesn't work, I have to ask, is there a specific reason you need XP Embedded? I was under the impression that using nLite to reduce the size of XP worked just as well.
Rok
« Reply #2 on: January 14, 2011, 03:38:55 pm »
The only access settings I have messed with are the ones under the control panel options. I am using XP Embedded because the hard drive I have (its in a thin client computer) is 1 gigabyte. If theres another avenue that would work better (I am extremely familiar with XP, just not XPE.) can you direct me to it?
« Reply #3 on: January 14, 2011, 04:41:42 pm »
In regular XP, you can also turn off the windows login by going to the start menu, clicking run, and typing in userpasswords2. Then there should be a box that needs to be unchecked that says something like "Users must enter a username to login"
If that works for you, and xp embedded works, then it is probably worth just sticking with it.
Otherwise, I know you can download nLite and use a regular version xp. It will step by step ask you what to remove from XP and then allow you to burn onto a new disc that has only these features of xp. I think generally, the size is under 100mb, and if you cut it lean enough, you get easily get it under 50mb. I don't know how much space you can work with, but this forum thread has a lot of info about what to chop off.
http://forum.arcadecontrols.com/index.php?topic=59373.0
I think on page 8, spystyle has a settings file on what he trimmed for his XP that seems to be working well. I haven't tried it, but I think you just need to load his settings file into nlite and it will set everything for you.
Hope that helps!  :cheers:
