Author Topic: Small bug with the order of items in the Info Window (Resolved)  (Read 2220 times)
markronz
  • Game on!
« on: January 07, 2011, 10:17:41 am »
I just want to be able to control what initial screen comes up when I press the Info button.   Within Mala, on the Info Window tab, I can set the order of the different info screens.   You would assume that the item that is on the top of the list would be the first item to be displayed when you press your Info button, but that is not the case.   When I press my info button, it's the second item on the list that gets displayed first.   The order works fine after that, but for some reason it shows the second item to start with.  This is easy enough to work around but I just thought I'd report it as it would seem it's not supposed to work this way.
« Last Edit: January 08, 2011, 04:24:52 pm by loadman »
loadman
  • Moderator
    • MaLa
Re: Small bug with the order of items in the Info Window
« Reply #1 on: January 07, 2011, 07:15:27 pm »
Cool
Another easy fix
Thanks for clear report  ;D
It will be fixed in next release
markronz
  • Game on!
« Reply #2 on: January 08, 2011, 10:31:58 am »
This is fixed as well.  The first item on the list is now the first item when you press the Info button.  Thanks!
