Author Topic: "List index out of bounds (2)" Error  (Read 13243 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: January 01, 2011, 12:49:26 pm »
fixed long ago
« Last Edit: January 27, 2011, 12:17:29 pm by MagicManPA »
MagicManPA
Re: "List index out of bounds (2)" Error
« Reply #1 on: January 02, 2011, 03:59:23 pm »
Anyone?
loadman
  • Moderator
    • MaLa
« Reply #2 on: January 02, 2011, 07:30:06 pm »
Anyone?
Hi.
I am not able to recreate this problem.
Are you able to post the mala.exe.log ?
This will tell me a lot  ;)
Enable in (see pic attached)
« Last Edit: January 02, 2011, 09:06:39 pm by loadman »
MagicManPA
« Reply #3 on: January 02, 2011, 10:04:49 pm »
2011/01/01  19:45:34.57   Error: Exception Message: List index out of bounds (2), Object Function: UnsetEmulatorHotkeys, Exception Class: EListError, Object Class: TfrmMain
loadman
  • Moderator
    • MaLa
« Reply #4 on: January 02, 2011, 10:16:47 pm »
Ideally, I want the log in debug mode in the seconds leading up to it to find out Why a bad value was passed.
I will try and work it out...  8)
MagicManPA
« Reply #5 on: January 02, 2011, 10:21:22 pm »
See attached
loadman
  • Moderator
    • MaLa
« Reply #6 on: January 02, 2011, 10:26:35 pm »
See attached
Thanks.
I had a look
I am not seeing that error since you enabled 'debug' logging.
I need you to recreate the scenario that created that error please and post that log.
MagicManPA
« Reply #7 on: January 02, 2011, 10:36:14 pm »
I did it during that session. Just did it again & the error came up, but it's, again, not in the log.
See attached
Thanks.
I had a look
loadman
  • Moderator
    • MaLa
« Reply #8 on: January 02, 2011, 10:43:37 pm »
Hi,
Interesting.   :-\
Questions:
1) When you say that 'error came up' what form exactly? Can you post a screen shot?
2) What the error occurs what are you doing with MaLa at that time?  Is it at the same type of spot consistently?
MagicManPA
« Reply #9 on: January 02, 2011, 10:48:44 pm »
I have attached a screenshot. It comes up whenever I try to create a game list for any emulator other than MAME.
Hi,
Interesting.   :-\
Questions:
loadman
  • Moderator
    • MaLa
« Reply #10 on: January 02, 2011, 11:34:21 pm »
Ahhhh..
That error is from the Editor rather than MaLa   ;D
Mystery solved, as the Editor is Launched from MaLa in that Scenario but is a seperate .exe. Hance Nothing In the Logs.
I will let you know if I need more info
loadman
  • Moderator
    • MaLa
« Reply #11 on: January 02, 2011, 11:38:08 pm »
Actually.
Can you please post your .mlg files  (game list files)
MagicManPA
« Reply #12 on: January 02, 2011, 11:44:31 pm »
Any of the game list files I try to make for anything outside MAME do not save. They end up just being a blank list.
Actually.
loadman
  • Moderator
    • MaLa
« Reply #13 on: January 02, 2011, 11:57:48 pm »
I am perplexed how and what is happening?  ???
I am just guessing here now and my time is limited   :'(
so....
Best Guess is a config file has got into a weird state.
I suggest you do either or both of the following.
1) Setup MaLa again  from scratch in a separate folder and see if the problem follows?
2) Zip up and send me (or a link to download) the contents of you MaLa folder that is giving you issues
MagicManPA
« Reply #14 on: January 05, 2011, 11:22:31 am »
I reinstalled MALA & it seems to be ok now, but I haven't touched it much since.
loadman
  • Moderator
    • MaLa
« Reply #15 on: January 05, 2011, 05:37:19 pm »
Hmm I wonder what config file was busted.
If you have the time and inclination send me a copy of your old MaLa config if you have it
loadman
  • Moderator
    • MaLa
« Reply #16 on: January 22, 2011, 04:37:43 am »
Is there any chance you were using BG music and the Jukebox and switching between them?
MagicManPA
« Reply #17 on: January 22, 2011, 10:18:07 am »
Nope, wasn't using bg music or jukebox.
Madman
  • Last login:September 01, 2017, 01:03:20 pm
« Reply #18 on: January 27, 2011, 12:13:56 pm »
Try taking a sample of mp3's and removing the punctuation from them.... (worked for me)
loadman
  • Moderator
    • MaLa
« Reply #19 on: January 27, 2011, 05:28:32 pm »
Yeah it seems to get upset if there are special characters in the song name.
I will look at this when I get time
