Author Topic: Layouts?  (Read 3257 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
Layouts?
« on: December 30, 2010, 02:25:43 pm »
I snagged several layouts from Mala's main site & some worked & some did not. I liked the N64 & NES layouts there, but they would not show up for me when I tried installing them.
Does anyone have a scalable Mala layout for N64, Sega Master System and/or NES?
Thanks.  :)
loadman
  • Moderator
    • MaLa
Re: Layouts?
« Reply #1 on: December 30, 2010, 06:13:19 pm »
Thanks.  :)
All the layouts work  ;D
Have a look at the MaLa Wiki on how to set them up. Link is on my Signature
Some need files in a folder, others do not
MagicManPA
Re: Layouts?
« Reply #2 on: December 30, 2010, 11:32:35 pm »
I tried both ways, but I'll take a look @ the Wiki.
Thanks.  :)
MagicManPA
Re: Layouts?
« Reply #3 on: December 31, 2010, 01:31:29 am »
Still getting the same issue. The game name list comes up, but the background does not.
danny_galaga
  • Last login:Yesterday at 01:01:05 am
    • dans cocktail lounge
Re: Layouts?
« Reply #4 on: December 31, 2010, 10:46:36 am »
I'm actually having trouble with background images at the moment, building from scratch. Hopefully same problem, and thus same answer (",)
danny_galaga
Re: Layouts?
« Reply #5 on: January 02, 2011, 07:12:11 pm »
I never quite figured out what my problem was, but I had a crude solution that worked. Since most of the work I had put into it thus far was with the graphics, I just canned that file and started editing the file called 'standard' instead, leaving the name the same. Only side effect there is Mala will keep putting the standard pics back in your standard folder. But that's no biggy, so long as you don't call your unique pics the same name  :D
loadman
  • Moderator
    • MaLa
Re: Layouts?
« Reply #6 on: January 02, 2011, 07:14:39 pm »
If you enable logging ( In Debug Mode) , it will tell you what file is looking for and where
« Last Edit: January 02, 2011, 07:28:00 pm by loadman »
