Author Topic: Bug - Mala 1.73 Page/Letter Up or down in gamelist scrolls gamelist (Resolved)  (Read 3210 times)
themadman
  • Last login:August 27, 2011, 12:48:20 am
Loadman,
I think I've found a bug in Mala; it actually sounds a lot like the volume scroll bug in another post (where pushing volume up/down will scroll the gamelist).
If you scroll the gamelist in either direction, then you try to go either a page(X) up or down or a letter up or down, the game list will move the page or letter, then it will go back to scrolling in the last direction that you scrolled by 1 as long as you hold down the page or letter movement key (either shifted or via a dedicated button).
I've tested this, and it occurs with an I-pac, a USB keyboard, and a PS2 keyboard, each individually plugged in. It also occurs in all version of Mala I had from 1.60 to 1.734. The only version I had that it doesn't occur in is 1.05.
Thanks for all the work you've done on Mala; Ive been a long time lurker here, and have used it since you took over development. I've not found any other frontend that meets my needs, and delivers the interface I want (none of the fancy ones with all the flash, give me what I'm looking for).
themadman
« Last Edit: January 08, 2011, 04:39:47 pm by loadman »
loadman
  • Moderator
    • MaLa
Re: Bug - Mala 1.73 Page/Letter Up or down in gamelist scrolls gamelist
« Reply #1 on: December 30, 2010, 12:27:15 am »
So it does  :o
Funny that nobody reported that before.
I will check it out  , and fix ;D
« Last Edit: December 30, 2010, 12:39:18 am by loadman »
themadman
« Reply #2 on: January 01, 2011, 01:37:39 pm »
Thanks Loadman!
I'll look for the new version when you post it...
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 02, 2011, 07:06:33 pm »
...Working on it  ;D
loadman
  • Moderator
    • MaLa
« Reply #4 on: January 02, 2011, 09:03:55 pm »
I fixed this.
It will be in next beta...
loadman
  • Moderator
    • MaLa
« Reply #5 on: January 03, 2011, 12:18:48 am »
OK.
Let me know how you go....  ;D
Download the latest beta here (link under the release version) :
http://www.malafe.net/index.php?page=download
themadman
« Reply #6 on: January 04, 2011, 11:02:30 am »
I Just grabbed it and will test it out tonight....
themadman
Thanks Loadman!
The beta looks good. Problem has been fixed as far as I can tell...
I'll make a donation to buy you some beer   :cheers:
loadman
  • Moderator
    • MaLa
« Reply #8 on: January 04, 2011, 09:54:47 pm »
mmmmmm Beer.
