October 17, 2025, 11:42:09 pm
There should be a volume pot near the coin door and another one on the sound board (though I believe it's a variable resistor on the sound board)I had an identical issue with same symptoms on my Spy Hunter, the VR on my cheap squeak board was dirty.
Always start with the connectors in a pinball machine. They are like beer - the cause of and solution to all of life's problems.
Have you replaced the amp section? Can you jump channels from the quiet one to a working one?
