Author Topic: Button/Joystick issue  (Read 2168 times)
mike boss
« on: December 24, 2010, 12:25:39 pm »
Just wanted to get an opinion here.
I recently sold my Tekken 3 Dynamo cabinet.
I did a hardware test and all the buttons + joysticks worked (all directions).
When the buyer got it home he said that some of the buttons/joysticks don't work.
I'm leaning toward it being an issue with the switches, which a few I have replaced in the past.
On the Tekken 3 he said when he pushes 1P punch + 1P kick it would  throw the opponent, however it doesn't work.
He also said player 2 directions don't work if fully pressed in the direction, but if presses 1/2 way work.
I can only think that it could be the joystick actuator & switches.
Does anyone think this could be part of a deeper board issue ?
Any thoughts ?
mike boss
Re: Button/Joystick issue
« Reply #1 on: December 27, 2010, 11:12:50 pm »
No thoughts ? Anyone ?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: December 30, 2010, 11:43:56 am »
I would walk the buyer through the hardware test like you did and then get the results from that first.
Some of the issues you described could be multiple things, including a bad ground that may have become flaky after moving the machine.
mike boss
« Reply #3 on: December 30, 2010, 03:22:38 pm »
Oh wow, I never thought of the ground.
Thanks for the heads up.
I will email the buyer now.
