Author Topic: Where to put CHD files?  (Read 34468 times)
MagicManPA
  • Last login:January 12, 2019, 04:35:43 pm
« on: December 20, 2010, 02:33:44 pm »
I tried making a folder w/the same name as the ROM zip file, but that didn't get the ROM to work.
What do I do w/the CHD files to get the ROMs to work?
MAME v103 & v140.
BigDaddyE
  • Last login:October 02, 2012, 01:52:48 pm
Re: Where to put CHD files?
« Reply #1 on: December 20, 2010, 03:25:54 pm »
You put the CHD's in the same file as the zipped roms.
Mame finds them and all is good.
Make srue you are running the same version CHD with the same version rom.
Eric
Someday this hobby will be easy for me!
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #2 on: December 20, 2010, 08:01:43 pm »
While the above will work... Make sure that you have the .chd files in folders named the same as the rom name.  If you want you can also have a separate CHD folder anywhere as long as you specify the path to CHD files in your MAME.ini.
MagicManPA
« Reply #3 on: December 20, 2010, 09:48:25 pm »
Maybe it didn't work for me before b/c I didn't do anything w/the ini file?
Never done anything w/that file.
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #4 on: December 20, 2010, 10:42:36 pm »
The default location for .chd files is located within folders with the same name as the rom in your ROMS directory.  If you don't change the default location then you don't have to worry about the .ini file.  However, there are a lot of settings in the mame.ini that can be adjusted.
MagicManPA
« Reply #5 on: December 20, 2010, 11:44:00 pm »
Then it should have worked for me hmm...
joemama
  • Last login:June 06, 2011, 04:11:36 pm
« Reply #6 on: December 22, 2010, 04:36:19 pm »
This is how I have my chd setup, not zipped.
\MAME\roms\kinst\kinst.chd
and for roms
\MAME\roms\kinst.zip
MagicManPA
« Reply #7 on: December 22, 2010, 11:43:20 pm »
and for roms
That's how I have them now & still no go.  :banghead:
WhereEaglesDare
    • My HomePage
« Reply #8 on: December 23, 2010, 12:00:42 am »
and for roms
delete the chd and download it again from a different source
