Author Topic: how to exit kega  (Read 19091 times)
portugese pirate
  • Last login:March 06, 2025, 06:07:58 pm
how to exit kega
« on: December 15, 2010, 03:02:02 pm »
Im running mala 1.71 with mame 1.36, stella, and kega fusion as the emulators. I have no problem exiting out of mame and stella games back to the mala front end. I cant seem to find a way to get out of kega fusion to get back to the front end. I have to keep right clicking on the mouse and exit that way. Is there another way? I also am using an X-arcade joystick with this, dont know if that really matters.....maybe there is a controller ini file for this?
newmanfamilyvlogs
    • Newman Family Vlogs
Re: how to exit kega
« Reply #1 on: December 15, 2010, 03:44:28 pm »
probably set up something like AutoHotkey to send an Alt-F4 when press some designated combination like P1 Start + P2 Start
portugese pirate
« Reply #2 on: December 15, 2010, 06:44:27 pm »
ok......so how do i do that ???
thatgammon
  • Last login:July 03, 2020, 05:25:03 am
« Reply #3 on: December 16, 2010, 07:48:14 am »
I would of thought hotkeys would be the way to go on Kega to exit.
Other Emu / Settings - Use hot keys.
But after looking at my setup i haven't used em.
Execution = "%path%\%rom%.%ext%" -fullscreen
Works fine. (ESC is quit)
portugese pirate
« Reply #4 on: December 18, 2010, 07:15:34 pm »
ok where do i put that at in mala
thatgammon
« Reply #5 on: December 20, 2010, 09:55:56 am »
Other EMU config tab
Highlight what you called your KEGA emu.
Execution tab
Put
in to command line
Try that I might of changed the .cfg file to do something I cant remember.
That works with mine.
portugese pirate
« Reply #6 on: December 20, 2010, 02:40:30 pm »
still same thing....Im ready to leave kega and go to another emulator just because of this ......any suggestions
thatgammon
« Reply #7 on: December 20, 2010, 05:52:44 pm »
well as i said, mine works so I am sure I can help you fix it if you stay with it.
Other emu config/options/use hotkeys
esc to close
Mine hasn't got that so I'm suggesting that might work OR tell me what happens if it dont.
As I said I MAY of changed the.cfg file to do something.
Also what are you using with KEGA, master system, genesis etc. That might be a factor
And what version of kega are you running?
« Last Edit: December 21, 2010, 03:43:08 pm by thatgammon »
portugese pirate
« Reply #8 on: December 21, 2010, 11:37:09 pm »
 I am using kega 3.6 to emulate the genesis.......ty
thatgammon
« Reply #9 on: December 22, 2010, 09:30:27 am »
Ok I downloaded Kega fusion 3.6 again so i am setting it up with the original settings (You may of changed something)
In mala, named the emu, pointed to the .exe and rom directory.
typed that in to the command line and it works a treat. (escape is quit)
tried this as well...
Other emu config/select your emu/options/use hotkeys
add hotkey (close) = ESC
Works using this method also.
The only thing I can think of is, Is Kega running fullscreen? If not then esc might not work, and yeah alt f4 prob is the only way from there.
But with the default kega settings, seems to work.
Let me know. (try the 2nd method, that must work)
« Last Edit: December 22, 2010, 09:34:02 am by thatgammon »
portugese pirate
« Reply #10 on: December 22, 2010, 04:42:28 pm »
still did not work :-[
thatgammon
« Reply #11 on: December 22, 2010, 08:37:22 pm »
Can you explain more?
Does Kega launch in fullscreen?
Did you download kega again (like I did) and try a new setup? Because I know it works with the default settings (which you may of changed)
Does escape exit your other emulators?
« Last Edit: December 22, 2010, 08:44:48 pm by thatgammon »
portugese pirate
« Reply #12 on: December 23, 2010, 12:41:03 am »
yes kega launches in fullscreen
yes ecape works on mame and on stella
no i did not reinstall kega but i will....and will get back to u.....ty for your help
thatgammon
« Reply #13 on: December 23, 2010, 03:10:29 am »
No problem mate!
We're close I can smell it!!!
Some1 else will benefit from this also.
When you download kega again, keep the original folder (use a different name for the new 1) as to compare.
Follow my previous steps and could you tell me what exactly happens when you hit esc (if it don't work)
portugese pirate
« Reply #14 on: January 02, 2011, 10:56:50 pm »
ok i reinstalled kega.........still have the problem kinda. It will now go back to mala by hitting esc button on keyboard, so that is a step in the right direction, but it wont exit to mala by hitting the player 2 button and and the player 2 coin on the x-arcade. we are getting closer....anymore ideas....ty for all the help
thatgammon
« Reply #15 on: January 02, 2011, 11:55:55 pm »
Well thats good  ;)
ok i dont have an x arcade. Does pressing those two buttons exit the other emulators then?
You mean there is no exit button on the x arcade?
portugese pirate
« Reply #16 on: January 03, 2011, 12:01:33 am »
yes those two buttons exit the other emulators and back to mala......there is no exit button on x-arcade. Is there away to change key assignment in kega..........so exit is those two buttons
thatgammon
« Reply #17 on: January 03, 2011, 12:19:45 am »
ok no not in kega.
download autohotkey and you can tell it to catch a combo of key presses to make an output, say
esc or alt f4. That would work.
I cant advise you on that cos i dont use it.
Well we got kega up and running, sorry couldnt be more help
elmago
  • Last login:January 06, 2014, 04:18:27 am
« Reply #18 on: April 10, 2011, 07:31:55 am »
I got exactly the same problem...and seemed so strange, because i use mala on 2 different pcs, one on my desktop pc, and other on my cabinet...(Windows 7 64bits)
After reinstalling Mala 1.74 on boths pcs, on the desktop one, all goes well, kega exits when i press ESC key, but when i try on my cabinet...it didnīt work...strange, cause both pcs use exactly the same config...just the same config that user  "thatgammon " has told on this post.
After investigating i solved the problem...and the problem (i think) was ATi Catalist center starting with windows, a few days ago i updated my card drivers and seem that ati catalyst auto configured to start with windows...
I went to star menu, tipped on windows search box this:
MSCONFIG
...and press return
A new window will open where you can see what programs are executing in windows start, i have no program checked, unless mala (on cabinet)...and yes, ati catalyst was checked too (cause i reintalled card drivers)...i unchecked the box, restarted windows and all goes well, Kega exits normally pressing ESC key (1p+2p button on my cabinet).
Hope this help someone.
