Author Topic: WELLS-GARDNER 27" ARCADE UNIVERSAL MONITOR 27K5201  (Read 5203 times)
Poker808
  • Last login:December 13, 2012, 11:39:41 pm
« on: December 10, 2010, 12:25:47 pm »
I'm thinking about buy a monitor from a guy which said he has a Wells-Gardner 27" 27K5201 monitor. It has been sitting on a shelf for 10 years and they are still in the boxes like new. Still have the plastic cover over the front class. He is asking 170 for the monitor and I was wondering if this would be a good deal. If I did buy this monitor can any of the veterians tell me how I would get this thing connected to my PC. I am looking to use it with mame, and any other emulator up to PSX. I think the specs said something about it only running in 25k mode or something like that.
Any information on this would be a great help. I just want to make sure I purchase something I'm going to like for a monitor in my arcade cabinet. currently I have a TV but it's just not the same.
Thanks,
ahofle
    • Arcade Ambience Project
Re: WELLS-GARDNER 27" ARCADE UNIVERSAL MONITOR 27K5201
« Reply #1 on: December 10, 2010, 01:29:52 pm »
Can you post the specs?  If it's a 25khz monitor (EGA) it's definitely not a good candidate for emulation as it will be limited to 512x384 resolution.
Poker808
« Reply #2 on: December 10, 2010, 02:58:00 pm »
I'm not sure about the specs but they guy did say it couldn't only do 25khz...The model is 27K5201 and the monitor part number is WGM2752-U0GS37F. I really can't find much information on this monitor.
Poker808
« Reply #3 on: December 10, 2010, 03:01:21 pm »
If this monitor doesn't work out is there any monitors out there right now that I should be looking at for a decent price. I know a lot of the well gardner monitors are not available. I'm looking to play a lot of emulators on my cabinet but want the old CRT feel.
ahofle
« Reply #4 on: December 10, 2010, 07:42:43 pm »
That's actually a good thing (it's probably a standard CGA arcade monitor).  If you can somehow find some specs on it, post them here.  If it's a 15khz monitor, that's definitely a good deal assuming it works.
To connect to a PC, you will need to hack a VGA cable (or buy a VGA breakout cable from ultimarc).  Use this guide to connect the appropriate wires to the monitor:
Then you'll either need to use Soft15khz to get low arcade resolutions, or buy an ArcadeVGA card from ultimarc.com.
Poker808
« Reply #5 on: December 13, 2010, 02:04:57 pm »
Sorry I ment it can only do 25khz, I think.
I can't find any more specs on this monitor.
Do you know what is available to purchase now a days for a arcade monitor.
MonMotha
« Reply #6 on: December 13, 2010, 02:18:30 pm »
For anyone reading this and seeing that wiring diagram above, DO NOT CONNECT PIN 9 TO GROUND.  This pin used to be empty (and as such could be connected however you feel like it), but it's now used for +5V (it was never used for ground).  So, of you connect that pin to ground, you're shorting +5V to ground.  Some video cards have protection to keep this from being too big of a problem, but many don't.
codecrank
  • Last login:August 04, 2017, 08:47:39 pm
« Reply #7 on: December 26, 2010, 02:42:22 pm »
if it can do 15hz ? You do all the emulation you want, run older games in progressive native res , up to 220 lines, ( work fine for most horizontal mame, nes, genesis, tg-16 ) and for snes and above, you can do 640x480, but it will be interlaced. ( personally , I can't stand interlaced.  )
but.. IMHO , 170$ is too much for a tube that only does 25hz . I just bought a used  tri-sync 27" kortek for 200$ shipped on ebay.  it can do 640x480 or 600x800 in progressive scan
