Author Topic: Problem with Z order in a new layout  (Read 4498 times)
tapule
  • Last login:July 19, 2018, 04:54:54 am
    • Gelide FrontEnd for Linux
« on: December 03, 2010, 06:22:48 am »
Hi,
I'm having problems with the Z order of video1 in a custom layout. I have, in this order, Snap, Video1 and Custom1 with a image that acts as a window. When there is no video, the custom1 is rendered above the Snapshot as I want, but when there is a video for the selected game, it is rendered above everything.
What I'm doing wrong?
Edit: Forget to say that I'm using mala 1.73
« Last Edit: December 03, 2010, 11:30:38 am by tapule »
Gelide FrontEnd for Linux http://gelide.sf.net
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
Re: Problem with Z order in a new layout
« Reply #1 on: December 03, 2010, 05:47:00 pm »
go to mala layout and change z order under the menu objects
tapule
« Reply #2 on: December 04, 2010, 01:46:35 am »
I think my Z order is correct:
Background
Snap
Video
Video2
Gamelist
Custom 1
loadman
  • Moderator
    • MaLa
« Reply #3 on: December 04, 2010, 02:27:21 am »
Sorry.
Video is 'always' on top at the moment.
tapule
« Reply #4 on: December 04, 2010, 02:30:16 am »
Ok Loadman, thank you.
Sibby
  • Last login:April 17, 2011, 11:30:52 pm
« Reply #5 on: January 24, 2011, 11:56:45 pm »
Hey Loadman,
I came across this in a search, as in my layout I'm running into the same issue.  I have an image that slightly overlaps parts of the video element.  You mentioned it's "always on top at the moment".  Do you have an idea of what kind of developmental effort it would take or when this bug may be addressed?
As always your time is appreciated.  Thanks!
loadman
  • Moderator
    • MaLa
« Reply #6 on: January 25, 2011, 04:42:44 am »
Big Effort.  Probably beyond me.  :'(
The rest of the graphics layers are easy as they are static and you combine and repaint.
An you can key over a video, but making the layout over the top is beyond me right now I think
tapule
« Reply #7 on: January 25, 2011, 10:19:11 am »
Loadman, this bug was always there? or there are any version in which this was working correctly?
loadman
  • Moderator
    • MaLa
« Reply #8 on: January 25, 2011, 07:11:15 pm »
It's not a bug
You could never layer videos.
Possibly I should change the layour editor so Video's do not appear in the list, I was being optimistic.
tapule
« Reply #9 on: January 26, 2011, 04:07:11 am »
Thank you Loadman
