Author Topic: Hyperspin closes when left running while I'm gone  (Read 4565 times)
kjbalto
  • Last login:January 20, 2018, 12:33:06 pm
« on: November 27, 2010, 02:39:53 pm »
I posted this question awhile ago. People suggested I try reinstalling hyperspin. I've reimaged my machine, I have a new internal hard drive I'm using (I was using an external drive before) and I reinstalled everything. When I launch Hyperspin, everything works great.  If I turn off my windows screen saver so hyperspin will just keep changing games on it's own, it will crash and close by the time I come back and look at it. Hyperspin will be closed and my taskbar is gone.  I have to hit ctrl+alt+del and run explorer again to get my start button back.  I can't figure out why this is happening. Like I said, new hard drive, new installation of hyperspin, but copied over all the old video files and everything.  That's the only thing that's the same.  Any ideas?
  • Last login:Yesterday at 09:34:29 am
Re: Hyperspin closes when left running while I'm gone
« Reply #1 on: November 27, 2010, 03:32:58 pm »
Are your power management settings in the control panel set to keep everything always on?
It could be shutting down the hard drive or going into sleep mode.
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #2 on: November 28, 2010, 09:21:13 pm »
This isn't an issue with HyperSpin.  It sounds like something more specific to your PC.  I leave HyperSpin running on my cabinet for days on end without any issues.  The only thing I have setup as power management is that my screen turns off after 30 minutes.
pinballwizard79
« Reply #3 on: November 28, 2010, 11:04:02 pm »
For me hyperspin will run fine maybe 50% of the time
Often it will load up missing random wheel arts (just some are missing & its different arts each reboot) or not load all the animations/art at the game menu.
Then it will close & never reopen again
Then I get a Blue screen with white text about how taskbar needs to close,
Then Dr watson pops up & tells me I am screwed
Then it reboots itself
Then it tells me in another blue screen how its really bad & must check the hard disc for errors
Then MS pops up & shows me 3 windows about " recovery from serious errors" & "sending reports"
I have a nicely powered & newly built PC which I've done several clean installs with on TWO hard drives.
If you figure out the gremlins please let us know, HS is so pretty I just have to get it working right. kjbalto sometimes I think it has to do with not letting the intro video play all the way & or not letting it load the very first theme 100% before scrolling to the next one.
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #4 on: November 28, 2010, 11:20:12 pm »
Often it will load up missing random wheel arts (just some are missing & its different arts each reboot) or not load all the animations/art at the game menu. This can happen if you have files other than .png in your wheel image folder.  This can also happen if your file names DO NOT MATCH those file names in the database.
1.  "Often it will load up missing random wheel arts (just some are missing & its different arts each reboot) or not load all the animations/art at the game menu." This can happen if you have files other than .png in your wheel image folder.  This can also happen if your file names DO NOT MATCH those file names in the database.
I'm running Windows 7 x64 and have no issues with my cabinet or HyperSpin.  I can leave my cabinet on for days and not see any issues at all.  I think your issues are related to XP or the version of XP you are running.  If I recall Dr. Watson was a bug ridden application.  Perhaps disabling Dr. Watson might help clear up some of your issues.
pinballwizard79
« Reply #5 on: November 29, 2010, 10:25:10 am »
Dazz I have FTP access & only downloaded your minted set so it cant be related to files other than .png or misnamed titles.
Dr watson does not cause the problems, its just a PITA program that irritates me with pop up windows of error information after its already very obvious something went wrong.
HS has started random shut downs on me too now just like kjbalto the OP
I can delete everything & redownload via the FTP but this is like the 3rd time Ive done that without a resolution.
Speaking of resolution, does that have anything to do with that (768 vs 1080 or etc).
Does HS not work correctly on XP? Ive loaded two different versions of XP thus far (MC & corp)
« Last Edit: November 29, 2010, 08:13:21 pm by pinballwizard79 »
