Author Topic: Setting it up  (Read 3485 times)
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
Setting it up
« on: November 24, 2010, 05:45:44 pm »
Hi there,
I'm just about to finish my frontend/emulator setup, and am almost ready to transfer it to my cab-computer. How exactly does this work? Do you just copy the whole setup to the cab-computer and strip down XP manually from there? Or do you fresh install a stripped version of XP and then add the setup in some way? And ifso, what are my options there?
Thanks!!
GoTheBunnies
  • Last login:September 15, 2011, 06:10:09 am
Re: Setting it up
« Reply #1 on: November 24, 2010, 07:41:38 pm »
Hi there,
Thanks!!
I used a disk-cloning utility (in my case I used Seagate Disk Clone.....but it requires a Seagate HDD to use). On an earlier install I started from scratch, but found that some of my mappings were wrong and it was a pain to re-check them. Disk cloning removes any risks of something not copying over properly - you know that everything will be exactly the same.
Good luck with it.
WhereEaglesDare
    • My HomePage
Re: Setting it up
« Reply #2 on: November 24, 2010, 11:17:57 pm »
instead of setting it up on one pc to move to another, why not set it up on your cab pc from scratch???
orchidius
Re: Setting it up
« Reply #3 on: November 25, 2010, 05:49:31 am »
Because it isn't capable of getting on the internet for one, and secondly, I didn't really feel like going through all that ---steaming pile of meadow muffin--- standing up in front of a cab fiddling with an ancient P4 computer.
There's the answer to your question, have you got one for mine? ;)
BobA
  • What Me Worry?
Re: Setting it up
« Reply #4 on: November 25, 2010, 09:28:06 am »
Is mame on a separate drive or is it on the main drive of your setup machine?   If it is on the windows drive it will not work to clone the whole drive to move it over as windows will not be setup correctly for your old P4 computer.  If it is on a separate data drive cloning will work just great.
orchidius
Re: Setting it up
« Reply #5 on: November 25, 2010, 10:48:11 am »
I made one huge directory with everything in it: Hyperspin, all the emulators, all the roms, all the artwork (still working on that). My Windows drives on the P4 are completely clean. I just formatted the whole thing.
orchidius
Re: Setting it up
« Reply #6 on: December 05, 2010, 06:45:56 am »
I was just looking around on google and found "tinyXP". Is that a good option? Are there others to consider? And once I got the OS installed, how do I get my frontend Hyperspin to launch on startup? And how do I hide windows completely?
WhereEaglesDare
    • My HomePage
Re: Setting it up
« Reply #7 on: December 05, 2010, 08:44:05 am »
instant sheller
orchidius
Re: Setting it up
« Reply #8 on: December 05, 2010, 09:32:10 am »
Thanks, that's just what I needed ;). 2 questions though:
1) Does this work on a fresh install of windows XP? It says you need service packs and whatnot. My MAME computer doesn't have network access, so downloading service packs is going to be a pain...
2) Would this work on TinyXP?
WhereEaglesDare
    • My HomePage
Re: Setting it up
« Reply #9 on: December 05, 2010, 12:10:31 pm »
« Last Edit: December 05, 2010, 12:14:31 pm by WhereEaglesDare »
orchidius
Re: Setting it up
« Reply #10 on: December 05, 2010, 12:29:15 pm »
Thnx, and what 'bout TinyXP?
WhereEaglesDare
    • My HomePage
Re: Setting it up
« Reply #11 on: December 05, 2010, 01:57:23 pm »
why not try it out?
orchidius
Re: Setting it up
« Reply #12 on: December 05, 2010, 02:22:20 pm »
getting tinyxp running on my MAMEpc would take me a couple hours probably the way things are stocked now. Better safe then sorry :).
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Re: Setting it up
« Reply #13 on: December 05, 2010, 05:08:37 pm »
i know that people have recommended cloning and all but..
I imagine both of your computers have the main drive labaled "C" drive
just make sure it's in the same location on the cab computer as the old computer
so if you have it as C/windows/users/shateredsoul/desktop/games/etcetc
then just copy your games folder to that same exact spot, I'm creating a game collection for my little cousin so I made everying in c/hyperspin
that way hopefully I can just copy it over to his pc when I see him during xmas.
orchidius
Re: Setting it up
« Reply #14 on: December 05, 2010, 05:56:42 pm »
Thnx for the heads up.  :)
