Author Topic: Substituting Wall Wart for batteries  (Read 1548 times)
SavannahLion
« on: November 14, 2010, 09:29:54 pm »
My daughter got this cool gizmo that plugs into the TV and plays... er.. nevermind that.
I've got a device that uses 3x C batteries. If memory serves me correctly, that amounts to 4.5v if the internals wires them serially. I haven't tested this, so I'm just speculating.
Cell phone wall warts run at about 5v. If I find a wall wart with enough amperage, wouldn't it be feasible to use three sabots in lieu of the C batteries and wire the wall wart across the sabots? I've never actually heard anybody doing this so is there something I'm missing?
MonMotha
Re: Substituting Wall Wart for batteries
« Reply #1 on: November 15, 2010, 01:34:32 am »
I can't think of very many power topologies that would be designed for 3x C batteries that wouldn't accept a 5V wall wart reasonably safely.  Of course, I take no responsibility if it does let the magic smoke out.  You are applying a slightly higher voltage than the "design" calls for.  You might chuck a ~1-2 ohm resistor in series just in case the design relies upon the batteries' inherent ESR for something.
  • Last login:January 30, 2026, 04:39:53 pm
« Reply #2 on: November 15, 2010, 01:19:15 pm »
Permanent switch or temp?  If permanent, you don't need 3 sabots...  just find where the (+) and (-) feed in and wire directly to those.
ahofle
    • Arcade Ambience Project
« Reply #3 on: November 15, 2010, 02:40:39 pm »
I do what you're suggesting all the time.  Just make sure the current is sufficient (1000mA is usually more than enough).
If you get an adjustable wallwart, they usually have a 4.5V selection already.
Like this:
http://www.phonemerchants.com/counacad50ca.html
SavannahLion
« Reply #4 on: November 15, 2010, 11:40:50 pm »
Temporary. If it was permanent, I would rather just hop down to the Hfe or Rat Shack and get the jack.
This may sound strange on a forum like this, but I actually abhor permanently modding electronics unless I absolutely have to. eg irreparable damage - exact replacement parts = hacking something in to make it work again.
