Author Topic: wheres the problem ?  (Read 12969 times)
tteettuk
  • Last login:December 28, 2011, 08:24:02 am
« on: October 30, 2010, 09:02:41 am »
Ive built a touch screen wall mounted pc, which is a jukebox.
A friend asked me to build him one so i did same components as the first one, but:
Sometimes his will not boot up ? he will leave it and then all of a sudden it boots up ? and sometimes it will boot up and then shut down and then start up, shut down etc and keep cycling through the boot up/ shut down motions.
It can happen (the boot up/shut down) on different stages of the boot up, bios page, loading windows etc any ideas ? thanks
tteettuk
Re: wheres the problem ?
« Reply #1 on: October 30, 2010, 09:18:52 am »
Hi forgot to mention it does not happen all the time, ive been round to see the pc/jukebox and it worked fine, so my friend videoed the fault for me, cause he thought i thought he was making the fault up !
« Reply #2 on: October 30, 2010, 09:50:33 am »
Sounds like either a bad powersupply or not quite connected cable somewhere. I'd go through and reseat everything. Is the mobo in an actual computer case or decased and just mounted to the inside of the juke case? Could be a grounding issue in that case.
tteettuk
« Reply #3 on: October 30, 2010, 12:50:29 pm »
The mobo is fixed a the wooden case thanks
