Author Topic: cabinet (empty) some extras [bay city, MI]  (Read 761 times)
guybrushthreepwood
  • Last login:July 27, 2011, 06:30:43 pm
  • “I wanna be a pirate!”
« on: October 30, 2010, 03:12:47 am »
Used to be pacman then was changed at a later date to an avengers machine. I have since repainted it (black). It's in decent condition but not a likely candidate for a restore. I have the orignial control panel which was modified by a previous owner to accommodate the avengers button layout (basically slaughtered), and I have another control pannel I had machined to fit 12 butons and 2 js but this doesn't work at all because the cab is too small. I also have the original monitor which has some burn in and has not been tested. I have the rails that hold the monitor currently set up to hold a computer monitor (which I have and is working) but the monitor just sits on the rails and is not bolted down , so it cannot be moved with the monitor inside or you risk it falling through :-[. I have the glass which is in decent condition. And I also have the avengers marque and board with jamma board (not tested). I decided to buy a different cabinet because this one is too small but it would be perfect for arcade classics. I need to sell it by the third because I am moving. I'm asking 25 on craigslist but if you tell me your from byoac all ill charge is a pizza and ill help you load it.
Im located in bay city, MI its about 2 hours north of detroit off I-75.g
I do have pictures but I cannot find my memory card reader. I would be happy to describe the cabinet in more detail if you give me a call.
My number is 989-891-7565. Please call because my internet is not on at the moment and it will be awhile before I can check my email. Oh and I don't mind late calls I'm usually up untill 4 or 5 am. I'll try and check this thread when I can but keep in mind im moving and really busy. Thanks guys!
If its past the 3rd and your reading this give me a call I might still have it.
