Author Topic: 2600 controller pinout.  (Read 1373 times)
paigeoliver
  • Awesome face!
« on: August 10, 2003, 05:51:34 pm »
I just got a Wico Command control joystick that I am going to put into a control panel. It has the Atari 2600 plug on the end of it.
I opened it up, and saw it just had leaf switches, and thus could be interfaced via I-Pac.
But how does the Atari 2600 pinout work? Does it have one ground? If it is easy, then I will just snip the cord and hook up the appropriate wires to the I-Pac. Otherwise I will have to rewire it from scratch.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
RandyT
    • GroovyGameGear.com
Re:2600 controller pinout.
« Reply #2 on: August 10, 2003, 07:50:35 pm »
DB-9 Cable.  5 of the connections are directions and the button, another is ground.  Just about as simple as you could want it :).
RandyT
paigeoliver
  • Awesome face!
« Reply #3 on: August 10, 2003, 08:29:45 pm »
Perfect. I was hoping I wouldn't have to rewire anything.
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #4 on: August 10, 2003, 08:35:59 pm »
nice thing about atari controllers is they are very simple... basically you have one ground pin, a pin for each input and two aux pins for either power or an analog axis (those paddle controllers).  So yeah you'll never have any trouble.  You could hack straight to a usb pad for that matter.
