Author Topic: Command-Line simple Image Viewer for GameLauncher?  (Read 1113 times)
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
« on: August 10, 2003, 04:08:47 pm »
Im trying to add a simple 'instruction' sheet  for my cabinet, within GameLauncher.   The idea is that one of the possible selections is a 'Help' item (an image with a help sheet), that would in turn be opened with a simple image viewer.
I cannot find a command line bare-bones image viewer that will work with Win2000.   The one that ALMOST did the trick was PictView, but it constantly crashes  (documented bug).
Anyone know of a simple image viewer for Win2K that is command-line based (CLI)?  The simpler, the better... the idea is to be able to do something like:
C:\myViewer.exe instructions.bmp -fullscreen
"3 warps to Uranus" -- so I stopped playing!
  • Last login:February 01, 2026, 01:32:52 pm
Re:Command-Line simple Image Viewer for GameLauncher?
« Reply #1 on: August 10, 2003, 08:32:15 pm »
nope no such thing.... you better just consider moving to a fe that supports these advanced features.
Justin
« Reply #2 on: August 10, 2003, 09:27:12 pm »
What advanced feature?  LOL
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #3 on: August 10, 2003, 09:55:29 pm »
Don't wanna argue with Howard but...
InfranView will work. It has a very good command line interface and it uses the [ESC] key to exit. Find it here:
http://www.irfanview.com/
Vallen Jpegger also has a good command line interface. However,  it uses [ALT]+[F4] to exit. You could work around that with a wrapper or key remapper if you had to though. It's here:
http://www.vallen.de/freeware/
Hope this helps!  ;)
All Your Base Are Belong To Us!
