Author Topic: Need help with pc mounting  (Read 2128 times)
yweiss
  • Last login:October 04, 2012, 03:34:31 pm
« on: September 26, 2010, 08:54:43 pm »
Hello everyone, I want to mount my motherbored on my pc case, i see that a lot of people do it but there is a problem, all my case is full with some wired screws that i dont know how to open them, so i want to know is there is a way to open them or shuold i use just cutter and pull them out?
10x for help
there is a picture of the scrwes
jimmy2x2x
Re: Need help with pc mounting
« Reply #1 on: September 26, 2010, 08:57:57 pm »
they look like rivets to me, to remove them I would use a drill
if you do this, it might be tricky to reassemble it
yweiss
« Reply #2 on: September 26, 2010, 09:10:42 pm »
so there isnt a way to open them?
i have to drill them and then they will fall down?
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: September 26, 2010, 09:18:15 pm »
they are rivets, you will have to drill them out if you want to remove them.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #4 on: September 26, 2010, 09:24:28 pm »
If you have a chisel you don't care much about, you can knock the heads off the rivets with a hammer and chisel and punch the rest through.  If the heads don't cut off, as long as you lift them a bit you can squish the heads with pliers until small enough to punch through.
Be careful if you try - lots of potential to hurt yourself.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #5 on: September 27, 2010, 03:39:37 am »
I have never seen a case riveted shut.  The rivet in your first picture looks like it is there to hold the power supply in place.  Right above that rivet looks like a normal screw hole to hold on the case's shell.  It looks like you have already removed this shell because we can see the bottom of the motherboard tray in your third picture.  This tray is NOT made to come out of the case.  It is part of the case.  You mount the motherboard to the opposite side of this tray (the inside part).  If you wish to remove the motherboard, you would remove the screws holding it in place.
« Last Edit: September 27, 2010, 03:45:18 am by JustMichael »
EwJ
« Reply #6 on: September 27, 2010, 04:33:54 am »
-1 for my reading comprehension.
I had thought you meant to remove the motherboard tray from the case to mount in a cabinet or something.  It seemed that way from your pictures as you have beaten the holy hell out of the case.
As JustMichael posted, some pc cases have motherboard trays that are fixed in position.
What makes this even more confusing is that in the 2nd picture it looks as though you have a motherboard installed.
Please elaborate on your goal here.
yweiss
« Reply #7 on: September 27, 2010, 10:55:16 am »
i wanted to mount to mother bored like he is in the cabinet,anyway eventually  I removed the mother bored and mounted it on a wood, but now i have problem i turn the pc on but i dont see anything, its writtien on the screen "analog power save" i think that there is a problem with the video card, i have a AGP slot and the card is in this slot, what can be the problem?
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #8 on: September 28, 2010, 01:47:37 am »
Re-seat the memory, video card, Ide/sata cables and the p/s wires. Sounds like it's not posting.
