Author Topic: Resistor Question  (Read 1672 times)
dieseldogpi
  • Last login:October 27, 2011, 02:40:41 pm
Resistor Question
« on: September 24, 2010, 07:10:12 am »
I need to replace a coup;le of resistors on my WG K7000.  My questions is what type of resistors do I get.  I know some are color coded, these aren't.  They are listed in the manual as 1.2 5% 2W MF....My most obvious guess is that these are 1.2 ohms, 5% tolerance, 2 watts, and Metal film?  When I went over to Mouse and put this info in, nothing came up.  Even on Bob Roberts site, there didn't seem to anything that matched exactly.  Are there ones that I can substitute for these, perhaps one that could handle heat a little better?  Thanks.
MonMotha
Re: Resistor Question
« Reply #1 on: September 24, 2010, 01:19:04 pm »
Sounds like metal film, yes.  Those would usually be a blue colored body.
Carbon Composition (dark brown body) or maybe Carbon Film (light brown body) can probably be substituted without issue.
If you're concerned about heat, Carbon Composition tend to hold up fairly well, but not much better than Carbon or Metal Film types.  You could also overside to a 5W if there's physical room.
My only concern would be if the slightly inductive nature of the metal film is required in this application.  Carbon Composition are very non-inductive.  I'm guessing it doesn't matter.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: September 28, 2010, 10:22:58 pm »
1.2 ohm @2w ... stick with a "flameproof" resistor  (MF)    :timebomb:
that value/rating is likely used as a fuse in your application  ( see schematic )
in this instance 1.55 amps allowing a maximum voltage drop of 1.86 v across the res
a flameproof resistor will open whereas the
carbon resistor will often produce open flame when ratings are exceeded.....
MonMotha
« Reply #3 on: September 28, 2010, 11:50:12 pm »
Is the part marked as a "safety critical" part?  Wells Gardner is usually pretty good about that.
