Author Topic: sound problem - "PlayList Load did not work" - Mala 1.71  (Read 2925 times)
shrunkenmaster
  • Last login:August 04, 2024, 02:53:35 am
« on: September 24, 2010, 12:33:16 am »
I've tried to add mp3s in the background music tab and am getting this error. Now, when I exit Mala (right click/options) I get the same error dialogue.
This still happens even if I turn off "enable audio".
edit: [debug log removed]
« Last Edit: September 26, 2010, 12:00:51 pm by shrunkenmaster »
loadman
  • Moderator
    • MaLa
Re: sound problem - "PlayList Load did not work" - Mala 1.71
« Reply #1 on: September 24, 2010, 02:01:30 am »
Thanks for the logs but I need the problem to happen while the log is set in 'debug' mode. I can see symptoms on 2010/09/23  but debug logging is turned on 2010/09/24 but no crash?
In any case does the problem happen with this beta? Link Below
*link removed*
« Last Edit: October 03, 2010, 09:26:25 pm by loadman »
shrunkenmaster
« Reply #2 on: September 24, 2010, 07:58:51 am »
Hello Loadman, I ran your beta from my Mala folder and got the same error. Attached (hopefully correct) logs from both versions, did the same thing both times:
start mala
options/config
[PlayList Load did not work.]
exit mala
Let me know if you need any other details.
loadman
  • Moderator
    • MaLa
« Reply #3 on: September 25, 2010, 02:05:33 am »
There does not appear to be any logs attached to your post.
You can rename the logfile to malalog.txt and then click 'additional options' on your post. You then get attachment options. As I state you may have to rename to file to something.txt to keep it happy.
Either way I will try  :)  But it's  hard if I can't reproduce and no logs  :'(
shrunkenmaster
« Reply #4 on: September 25, 2010, 03:07:46 am »
Sorry my man, been burnin' the candle at both ends. Files attached.
loadman
  • Moderator
    • MaLa
« Reply #5 on: October 03, 2010, 04:54:57 am »
Hi,
Sorry for being slow but I don't see a crash in those logs.
What dialogue might that be?
I'm sure we will get there soon   ;D
« Last Edit: October 03, 2010, 04:56:31 am by loadman »
shrunkenmaster
« Reply #6 on: October 03, 2010, 08:44:47 am »
Hey Loadman, I'll run it again and post the log when I'm back at the machine later.
The dialogue is as before: PlayList Load did not work
loadman
  • Moderator
    • MaLa
« Reply #7 on: October 03, 2010, 09:10:44 pm »
Ahh,  ::)
I can see where that is triggered in the code now  ;)
It could be for a number of reasons.
I don't think I have fixed the problem (as I could not recreate it) but I did add extra logging in the code.
Please try this version ,
Post log when/if it breaks again. Thanks
Download link is on this post:
http://forum.arcadecontrols.com/index.php?topic=105684.msg1126652#msg1126652
« Last Edit: October 04, 2010, 01:08:33 am by loadman »
