Author Topic: Ok, I give up. What is this thing supposed to do?  (Read 3489 times)
Stobe
  • Trade Count: (+17)
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Ok, I give up. What is this thing supposed to do?
« Reply #1 on: September 22, 2010, 02:43:31 pm »
http://uk.gamespot.com/features/6196930/index.html
"The new system has the same video-out port and uses the exact same video cables as the PSP-2000, but Sony has upgraded the PSP-3000's video output to support gameplay output on interlaced displays using composite video cables. The move will surely excite gamers dismayed over the fact that the PSP Slim can output gameplay video only to progressive scan displays. Now they can buy a new PSP instead of an HDTV. "
Stobe
« Reply #2 on: September 22, 2010, 03:16:09 pm »
I think you're more confused than I am.  Look at the connections on the cable i linked to.
I have a PSP cable for video output.  I actually have a composite, and a component.  But they use the special connecter tied in with the earphone jack for video output.
The cable on ebay has a USB male connector and 3 female RCAs.  I didn't think the PSP outputed any video via USB, and certainly not a full sized USB.
And if I were to turn it around, I could certainly connect the RGB RCAs to my component output cable, but then where would the USB male connector go to?
But thanks for that link.  I have tried to connect my 2000 PSP to my downstairs TV (only Composite, not component), and it gave me the error about needing a component display.  I'll have to try the composite cable with my daughter's 3000 to see if it works as that article stated.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #3 on: September 22, 2010, 06:38:16 pm »
I have an old, fat PSP.  I don't even know how it outputs video.  Never tried, nor will I.  But it certainly isn't through a full-sized USB, as it doesn't have a female full-size port.  It does have a mini-USB port for charging and data transfer, but I don't know about video.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
danny_galaga
  • Last login:August 19, 2025, 05:23:43 pm
    • dans cocktail lounge
« Reply #4 on: September 23, 2010, 01:22:01 am »
Next time, just cut the first part of the ebay link, like so:
http://cgi.ebay.com/For-PSP-USB-to-3-RCA-Colored-AV-Video-Converter-Cable_W0QQitemZ260524967695
There's a whole buncha superfluous stuff in ebay urls for some reason...
About your question, I got nuttin!
« Reply #5 on: September 23, 2010, 02:22:33 am »
For PSP USB to 3 RCA Colored AV Video Converter Cable
Description:
    * This USB to Video Converter Cable is a piece of USB to 3 RCA RGB Female Video Converter Cable for PSP, which can convert USB male connector to 3 RCA female to provide convenient connection for your PSP system.
    * USB to 3 RCA RGB Female Video Converter Cable for PSP.
    * Convert USB to 3 RCA female.
    * Color coded connectors, easy to connect, no drive needed.
    * Note: this item can't be connected to computer via its USB connector for AV output because the computer' USB port doesn't have AV output.
    * USB to RGB Cable Length: approx 16cm
    * Cable Color: as picture show
C'mon guys, they said it three times...clearly it's a  USB to 3 RCA RGB female Video Converter Cable  for PSP.
do-hicky-thing-a-ma-bob.
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #6 on: September 23, 2010, 10:37:10 am »
I've seen some digital cameras use a USB-> RCA cable for video out, but they are just utilising the connections (USB is turned off, and it routes video/audio to the USB pins. Probably Vid, Left Audio, Right Audio and a shared ground)
This won't do anything unless 1) the PSP has been designed to pass out analogue video/audio directly onto the USB pins. 2) The cable itself has an inbuilt USB device that can interface with the PSP to clone the framebuffer. This would require drivers on the PSP firmware/OS (so design or homebrew) as well as a spectacularly small USB device and AV decoder in the USB plug. Given the price, that is not the case.
(1) is the only viable option here, and I did not think PSP's could do this - but I don't own one. There is PSP homebrew software that lets you clone the video onto the PC screen via USB - but that is a USB->USB cable, and they simply pass the framebuffer as data to the PC and let the PC decode the image.
Stobe
« Reply #7 on: September 23, 2010, 11:00:00 am »
I'm just beginning to think its a simple typo.  Its listed as a "piece of USB", and I think it should be listed as a "piece of -*self sensored*-"  !
hypernova
« Reply #8 on: September 24, 2010, 06:32:22 pm »
Can you charge a fat PSP through the USB port???
Oops.  No.  Separate connection for the AC adapter.
Or at least, I don't think you can charge it via the mini-USB.  Never tried.
lilshawn
  • Last login:August 19, 2025, 11:56:37 pm
« Reply #9 on: October 07, 2010, 02:54:18 pm »
but the PSP STILL doesn't have a full sized usb port on it! soooooo.... yah i got nothin'
this one gets me though...
so now i can feed monitor sounds too?! bzzzzzztzttztztttttzzztt..  :lol
newmanfamilyvlogs
« Reply #10 on: October 07, 2010, 03:17:55 pm »
The proper way: :D
http://www.bombshock.com/electronics/cable-descrambling/tv-scribble-vision.html
Used to do this with old TVs years ago. Always made me wonder if it would be possible to rig a second soundcard to an amplifier, connected this way, and drive the yoke for a home-made vector monitor kind of like this guy did with an oscilloscope:
http://blog.makezine.com/archive/2007/08/youscope_oscilloscope_dem.html
