Author Topic: transferring mamewah problem  (Read 1436 times)
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« on: August 09, 2003, 08:17:14 pm »
I have mamewah/mame067b running on my pc with xp and it works great. I coppied them to a disk and put them in my cabinet which is 2000 and it does not work. There is no rom list and it keeps saying
run-time error '75':
path/file acces error
I tried deleting the cfg files and starting over but it still does it.
HELP
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
Re:transferring mamewah problem
« Reply #1 on: August 09, 2003, 10:28:02 pm »
I'm pretty sure that Mamewah cannot just be "copied" over directly to another computer, it has to be installed to ensure the correct dll files etc.. are transfered.
I'd suggest getting the installer from the Mamewah website, installing that on your 2000 machine, then copying your appropriate config files across (make sure it is the same version of Mamewah, as the config files changed structure recently).  Also ensure that your rom directory paths are the same on the 2000 machine so the config files point to the correct locations.
dirt
« Reply #2 on: August 10, 2003, 03:56:18 pm »
my 2000 machine has no internet access.is there anyway else to do it?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #3 on: August 10, 2003, 04:02:04 pm »
yea, just download the .zip file (or .rar or whatever) onto your xp pc. DO NOT install it. then just burn that file onto a cd. install it on your 2000 pc.
It's all about the Pentiums
dirt
« Reply #4 on: August 11, 2003, 12:44:47 am »
for some reason the new version didn't work when i tried this but the older one did so at least it is working now with the older version.
thanks
dirt
