Author Topic: MAMEWAH & FCEultra help!  (Read 1424 times)
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« on: August 09, 2003, 08:17:04 pm »
I have my settings, I think, correct. When I try to load a game from MAMEwah i get "Error Loading"  and some short numeric code, depending on the rom it is trying to load. Anyone have an idea why i can't load up FCEultra/nes roms with MAMEwah?
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
Re:MAMEWAH & FCEultra help!
« Reply #1 on: August 09, 2003, 10:19:57 pm »
Not sure what might be going on, but ensure you have your Show dos box, send rom path and send rom extensions set to true.
Here is my config for FCEUltra if it helps.
;EMULATOR OPTIONS
Emulator Title = Nintendo
Emulator Executable = C:\Emulation\Nintendo\fceu.exe
Default Options =
Extra Options #1 =
Extra Options #2 =
Show DOS Box = 1
Send ROM Path = True
Use Long Filenames = False
Send ROM Extension = True
DAT Filename =
NMS Filename =
CatVer Filename =
ROM Path = C:\Emulation\Nintendo\roms
ROM Extension = ZIP
List Generation Method = 0
Artwork #1 Image Path = C:\Emulation\screenshots\nes\screens
Magnet_Eye
  • Feel the heat?
« Reply #2 on: August 09, 2003, 11:28:38 pm »
THANKS! I GUESS I NEEDED SEND ROM PATH/EXTENSION SET TO TRUE. WORKING NOW.  ;D
Hey, once your in fceultra, how do you exit it back to MAMEwah? I have to use F12 to close it out. Once I put this in my cab, what do I do? Can I change the key to ESC?
stuzza
    • ScreenshotArchive
« Reply #3 on: August 10, 2003, 03:16:48 am »
Unfortunately you can't configure the Esc Key in FCEUltra.  I use a program called "Hot Keyboard" which enables me to assign a key that will call an "Alt+F4" allowing me to close any open window with the one keystroke (mapped to a button on my cab).
If you need a NES emulator that you can exit with Esc, try VirtuaNES.
