Author Topic: MAME32? Losing Tab key... ?  (Read 1566 times)
NatasNJ
  • Last login:December 19, 2003, 04:10:03 pm
« on: August 09, 2003, 07:28:31 pm »
When I install MAME32 (.71) everything seems to work fine.  Then after a few days I seem to lose the ability to use the tab key in the menus..   ANyone know what can be causing this?  It has happened 2-3 time already...
Going to delete EVERYTHING.  Reinstall newest version.  And see what happens.  And see when I can pinpoint this problem if it happens again.
Ideas?  Thoughts?  Suggestions?
SirPeale
  • Green Mountain Man
Re:MAME32? Losing Tab key... ?
« Reply #1 on: August 09, 2003, 07:43:37 pm »
Delete default.cfg from your cfg folder.  Fixes everything.
NatasNJ
« Reply #2 on: August 09, 2003, 08:23:14 pm »
Will try it.. Thanks...
NatasNJ
« Reply #3 on: August 10, 2003, 01:24:43 pm »
Worked.  Thanks..
Any explaniation of why that happens?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #4 on: August 10, 2003, 01:58:47 pm »
someone changed the menu key to another key, so your .cfg had to be deleted to reset the assignments.
It's all about the Pentiums
NatasNJ
« Reply #5 on: August 10, 2003, 02:09:28 pm »
That makes sense.  But the problem is No one did change the key!  Unless it happened under complete random chance.  (Under each set of installs)
Just seems weird....   Thanks for the help guys....
