Author Topic: Guide to configure LED-Wiz for MALA.  (Read 3980 times)
Blackus
  • Last login:April 22, 2011, 03:15:58 pm
« on: September 17, 2010, 06:02:05 am »
Hi
I have connected the led-wiz to of led s the RGB in the push-buttons. I have Connected the led-wiz to usb, I have installed ocx and copied all the file of the plugin for mala in the folder plugin (Mala's folder)
Mala in the options of the plugin see the ledwiz therefore the use the configurator for configure some led (the first 9 input). Starting Mala however it does not happen nothing. Is some other step to make? Exist a detailed does guide.?
Re: Guide to configure LED-Wiz for MALA.
« Reply #1 on: September 17, 2010, 07:44:23 am »
You might grab a copy of LEDBLinky first, just to test that the LEDWiz is installed and that you can turn on and off specific LED's at will.
Once you've verified that, this you'll know you've just got a mala config issue.
Blackus
« Reply #2 on: September 17, 2010, 10:13:26 am »
I do not understand as Ledblink is used...
Blackus
« Reply #3 on: September 30, 2010, 05:48:46 am »
up
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #4 on: September 30, 2010, 08:40:24 am »
drventure is suggesting you use the LEDBlinky software just to confirm that your LEDs are wired and working correctly. You can also use the software provided by GroovyGameGear to test the LEDs?
Maybe post this question in the MaLa forum.
Robots will kill you.
Arcade Addiction
