Author Topic: Think I Need a Power Supply  (Read 2127 times)
Med
  • Newbie
  • Last login:January 08, 2011, 12:03:05 pm
« on: September 15, 2010, 10:45:13 am »
I have a Captain America machine (seen here) that recently stopped working. I am getting power to the marquee and the monitor appears to be on. What isn't working is the jamma board and the coin door lights.
After reading a bit on the forums I believe that the power supply on the floor was the problem. A friend had put a voltmeter on it and indeed there was voltage going in, but nada coming out.
Can you recommend what power supply specifically I should purchase to replace it, and also where would be the right place to go (ebay, online store, etc.). Thanks in advance.
BobA
  • What Me Worry?
Re: Think I Need a Power Supply
« Reply #1 on: September 15, 2010, 07:38:31 pm »
You can get these from any arcade part supplier or you can use a PC supply with a jumper.
Link PS
JRoz
  • Last login:February 14, 2024, 07:33:43 am
« Reply #2 on: October 08, 2010, 12:27:16 pm »
Hey what type of jumper do you need for a PC power supply?
BobA
  • What Me Worry?
« Reply #3 on: October 08, 2010, 10:20:43 pm »
« Last Edit: October 09, 2010, 02:49:39 pm by BobA »
gShooter
  • Last login:March 10, 2016, 02:12:46 pm
« Reply #4 on: November 08, 2010, 12:42:17 pm »
From this weekend, a single piece of solid core 18 gauge wire works well as the jumper.
