Author Topic: Wells d9200 no osd  (Read 2766 times)
fargen
  • Last login:July 09, 2017, 01:11:56 pm
Wells d9200 no osd
« on: September 15, 2010, 02:34:24 am »
heya guys, I have two neck boards that wont let me into osd. I have a newer neck board off of working unit and when installed into each one the osd comes on. I have changed ic201 but didnt help. Obviously it is a neck board issue but dont know of anyone else who had this problem Any ideas? thanx sbm
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Wells d9200 no osd
« Reply #1 on: September 15, 2010, 11:23:51 pm »
verify 5v B+ to ic202 pins 5,24
and check pins 7,8 for activity when osd activated
osd rgb out to ic201 via pins 19,20,21 with blanking on pin 22
Hsync in pin 6
Vsync in pin 17
grantspain
« Reply #2 on: September 16, 2010, 07:59:21 am »
ic202 controls the osd
fargen
« Reply #3 on: September 20, 2010, 10:28:18 pm »
Changed 201 and 202 , no change. this is getiing to be a pain in the but since I dont know where to go on this issue.
qrz
« Reply #4 on: September 21, 2010, 09:34:56 pm »
have data activity on pins 7,8 of ic 202 ? (uses a i2c bus from the uP )
MUST have H/V sync input on pins 6,17 respectively...
grantspain
« Reply #5 on: September 22, 2010, 05:41:26 pm »
must be 9200 death time,i had one go bang today
i was working through mine today and actually got it running again but having issues with signal-i did some checks that may interest you
take a reading of the +12 onto the neck card,its marked on the plug-if it reads a good 12 v then trace that through the card
