Author Topic: Video output to TV  (Read 2736 times)
Video output to TV
« on: September 14, 2010, 07:31:24 pm »
I'm looking at different options to output from a video card to a TV and would like some input.
If I find a card with a VGA or even DVI output, is there a simple way to convert the signal to either standard video in (ie yellow phono-style jack) or to an S-VHS input?  Or, do I need to look at something specific, with a specialized output? (I'm looking cheap, obviously.)
I would read more, but it's difficult to navigate on my BlackBerry. I'm hoping this is a simple answer.
Re: Video output to TV
« Reply #1 on: September 17, 2010, 12:44:54 pm »
Well, I'm not on my Blackberry now, and since nobody jumped in to call me a noob (appreciated), I found it myself.  It's cheap, locally available, and makes me a happy monkey.
MonMotha
« Reply #2 on: September 17, 2010, 12:50:22 pm »
That cable is designed for some oddball projectors and laptops that specifically support it.  I've NEVER seen a PC that supports that.  It won't work.
The simplest option is to get a video card for your PC that has TV out or buy a device known as a "scan converter" that will plug into your VGA port and output Composite/S-Video.  The latter is available online for ~$25-50.
« Reply #3 on: September 17, 2010, 12:55:18 pm »
Damn.
Thanks!  Will keep an eye out.  Very much appreciated.
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« Reply #4 on: September 17, 2010, 01:30:05 pm »
Take a look at soft 15khz over in the 'Monitor/Video' forum.  Not sure if you can connect directly to a TV with it though.
The reason I suggest trying soft 15k is that it's free and so easy that I got it to work!!!  Also, you can use just about any video card you want.
MonMotha
« Reply #5 on: September 17, 2010, 01:35:18 pm »
You cannot unless you have a TV with e.g. RGB SCART (reasonably common in Europe but not the rest of the world), though it can be used with an outboard RGB to S-Video (NOT a scan converter) or RGB to YPbPr component adapter to get native video on a TV.  The results are usually MUCH better than a scan converter or onboard TV out as it avoids a bunch of scaling,  but it does require more work.
newkillergenius
  • Last login:September 21, 2013, 03:48:35 pm
  • A mind is a terrible thing to taste.
    • The Mystery Revealed!
« Reply #6 on: September 17, 2010, 01:35:57 pm »
Rick, if you need an AverKey I will send you one for the project.  LMK.
Good, but not the best.
MonMotha- there ain't no way that set he has has SCART dude!  It's fulla hornets too!   :dizzy:
Slider2732 got this to work for him, he likes it and says there is no tearing, and it will work with most composite or s video output cards (of which I also have a few extras...)..... :dunno
« Last Edit: September 17, 2010, 01:39:31 pm by newkillergenius »
Don't ---steaming pile of meadow muffin--- where you eat, my friend.
« Reply #7 on: September 17, 2010, 02:01:14 pm »
I appreciate that, thanks!  Let me check into my stock of hardware I have at home - I have a box of motherboards and video cards, and if I remember correctly, one of the video cards may be an ATI All-In-Wonder AGP, and I believe it has a TV out...  I'm not entirely sure.
If I need it, I know who to call!  Thanks again!
MonMotha
« Reply #8 on: September 17, 2010, 02:36:40 pm »
I've had very poor luck getting native video out of the TV out (S-Video/Composite) on PC cards.  They always seem to want to scale it.  Maybe the newer stuff is better.  I've mostly been using old crap I had laying around.
I didn't figure he had SCART.  I just knew that if I said it couldn't be done, SOMEBODY would helpfully "correct" me.
newkillergenius
« Reply #9 on: September 17, 2010, 05:43:15 pm »
y,y, no worries, just fartin' around with what I have seen done, the AIW should have the composite video output, but S will look better if you have to go this route.  (and it may have that too- I cant remember.  been a while since I saw an AIW.)
BurgerKingDiamond
« Reply #10 on: September 30, 2010, 07:08:47 am »
I got a cheap video card for like $35-$40 with S-video out on Newegg, and I got a 27" CRT with s-video and comonent input for $45 at a pawn shop just a couple weeks ago. The picture looks great and for under $100 I don't think you can go wrong.
-Welcome to the Fantasy Zone.
newkillergenius
« Reply #11 on: September 30, 2010, 10:17:13 am »
Regardless your username is ---smurfing--- hysterical  :cheers: :laugh2:
« Last Edit: September 30, 2010, 10:19:24 am by newkillergenius »
