Author Topic: Juke box problem  (Read 2982 times)
vinnypp
  • Newbie
  • Last login:September 15, 2010, 08:16:09 pm
Juke box problem
« on: September 14, 2010, 06:06:53 pm »
I have a R-94 Rowe  jukebox.
All of a sudden the tone arm goes into the middle of the record instead of playing from the beginning.
The tone arm returns to the proper location at the end of record play but the tone arm travels to the middle of the record when another selection is chosen.
This machine only has 1000 plays on it.
All help is greatly appreciated.
Thanks,
Vinny P
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
Re: Juke box problem
« Reply #1 on: September 21, 2010, 08:59:57 pm »
First thing I'd check is to see if anything is obstructing the tone arm travel.
They usually don't just 'fall out' of adjustment that far that quickly.
Look at the base of the tonearm, maybe the shaft could use some oil.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: September 21, 2010, 11:30:20 pm »
The copper tone arm guide piece on the tone arm cam may have broken off. See your manual for pictures of it and to get the part number.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: September 22, 2010, 11:53:08 am »
Hello Vinny P,
Yes Ken is correct it could be the guide but it is white plastic not copper.
Another thing to check is that the two pins on the rear of the tone arm that go over the tone arm are intact and are following the tone arm cam correctly check out your manual.
Regards
Alan Hood
ami-man
UK
golyo79
  • Newbie
  • Last login:September 26, 2010, 02:35:00 pm
« Reply #4 on: September 26, 2010, 02:35:00 pm »
Rowe Ami cd100E jukebox I look for a lamp
Yellow, red
if somebody can please let him sound thank you
Or how drew substitute one melted??
ami-man
« Reply #5 on: September 28, 2010, 06:21:39 am »
Hello golyo79,
The lamps you require are a type 73 1watt 14 volts, more than likely the substitute ones you used will have been the incorrect voltage or wattage.
Use of these may have effected your sound to light unit, I would check out that there is no dry joints (called cold joints in the USA) on the sound to light lanp connection sockets.
Regards
Alan Hood
ami-man
UK
