Author Topic: Help about drill holes  (Read 1156 times)
yweiss
  • Last login:October 04, 2012, 03:34:31 pm
« on: September 14, 2010, 07:49:15 am »
Hello everyone, I ordered now some classic pushbutton from ultimarc.com, I know that I need to drill a 28 mm hole but this is the problem..
I went today to buy 28 mm drill bit but I didnt found, I founded 22 mm, 25mm, 30mm,  and even 29mm hole saw but 28 I didnt found the wirdest thing is that I found a hole saw that it is  1 1/8" and I know that its is good but it was 29mm and not 28mm, so I want to know what bit drill should i get? 25mm? 30? or  1 1/8" thats its 29mm?
10x for helping..
EvilNuff
Re: Help about drill holes
« Reply #1 on: September 14, 2010, 08:36:20 am »
You want to get the smallest one that fits your buttons.  I would go with 1-1/8" which is 29mm.  That will fit the buttons you have.  A little bigger is ok, it just means the button won't fit snugly but when you tighten it down it will hold firm and not move.
  • Last login:Today at 09:15:18 pm
« Reply #2 on: September 14, 2010, 08:39:30 am »
Thank you for posting this.  I had just read this thread, and was actually wondering what damage going with smaller holes would do.  I can only imagine it would wreck the threads, and probably feather/destroy some of the MDF (if that's what's being used) and your solution makes a world of sense.
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« Reply #3 on: September 14, 2010, 08:48:34 am »
Get the 1-1/8".  I think that is what Happ recomends for drilling holes for their buttons.
If nervous, just take some scrap wood and do a test.
MY FIRST BUILD:
yweiss
« Reply #4 on: September 14, 2010, 09:12:32 am »
So you saying that 1-1/8" which is 29mm and 30mm are both good for me?
PsychoMikey
« Reply #5 on: September 14, 2010, 10:27:28 am »
If you also want to drill trough plexi i would get a step drill bit. I also was looking for a spade drill but could never find them the right size so ordered a step drill (12-28 mm)  online. Drills perfect in MDF every time :)
Mikezilla
« Reply #6 on: September 14, 2010, 11:40:31 am »
Yeah the step drill bit works great, but its a little pricey. Whatever you do, dont use a spade bit for drilling plexi at least. Wood is fine, but in my expierience it was a nightmare to try and do it on plexi. Then again Im not exactly Mr. Fixit or anything, so I could have been doing it wrong, but I posted a thread and followed everyones advice and I still screwed up so I said "F this Im getting a step bit". Worked like a charm!  :laugh:
