Author Topic: help needed super space invaders 91 restore project  (Read 6725 times)
cyberduck16
  • Last login:October 30, 2010, 01:54:38 pm
« on: September 08, 2010, 10:53:36 am »
hi I'm completely new here just looking for some general advice i have picked up a super space invaders cocktail table the glass is cracked so i have removed it and rubbed down the top ready for a respray the main board inside is loose also i can only here a few sounds from the speaker if you turn it up all the way you can here the space invaders moving but only a whisper i have tried another speaker but that was the same any help would be great as this is the first time i have ever attempted anything like this
thanks in advance
cyberduck16
Re: help needed super space invaders 91 restore project
« Reply #1 on: September 08, 2010, 10:55:35 am »
here are more pics
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: September 08, 2010, 04:56:43 pm »
Regarding sound, look on your board in the upper right you see that white plastic thing with a + in it? (like a screw). You can turn that for volume. Use a plastic tool if you are worried about slipping and touching something, since its easier to adjust with the game on. Also be very careful not to touch anything related to the monitor, there's lots of high voltage in there.
To secure the board, you can use screws and blocks of wood, and / or "pcb feet".
What other advice did you want?
PS: Use periods so we can see where sentences start and stop. Makes it easier to refer back to questions you asked. They don't teach this stuff in school just to be annoying. It makes people better communicators.
« Last Edit: September 08, 2010, 05:07:06 pm by RayB »
NO MORE!!
cyberduck16
« Reply #3 on: September 09, 2010, 06:37:40 am »
Hi there
Sorry for the bad punctuation. I have turned the volume up all the way and it's still very quiet yet the blast sound effects are really loud. Was also wondering how the coin slot mechanism works as mine does not register coins being put in. Also is the screen supposed 2 flip for second player as mine does not.
RayB
  • There's my post
    • RayB.com
« Reply #4 on: September 09, 2010, 01:23:08 pm »
Coin issue: Is the game in free play mode? It wont register coins if it is. If it's not, there's a switch with a little metal wire that activates when a coin hits it. Check that. Flick it down with your finger til it clicks. Does that register a credit?
Sound: I have no idea what's going on here, but its obviously not the speaker or the wiring...
Screen flip: You need to find the manual and look up what the dipswitch settings are and then you set the board to cocktail mode. This will be either through a box of tiny switches on the board itself, OR through "service mode" menu in the game itself. (Again, the manual will tell you how to access this menu)
NO MORE!!
cyberduck16
« Reply #5 on: September 09, 2010, 02:23:18 pm »
the little black switch on the coin slot does work but appers to have the wire snapped off of it. how would i know if it were in free play mode? i have installed a switch instead of the coin slot for now to add credits
any ideas where i would find a manual?
cyberduck16
« Reply #6 on: September 09, 2010, 02:34:58 pm »
ive found the dip switch settings and now have the screen fliping
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: September 09, 2010, 03:01:07 pm »
There would have had to actually be some punctuation for it to be bad.  ::)
Every online source that I know of for manuals/pinouts/dips is in the Restoration section of the wiki, but I don't think I have ever seen a Super Space Invaders manual in any of them.
Working: Not Enough
Projects: Too Many
Progress: None
Paladin
  • Mmmm llamaburgers!
« Reply #8 on: September 09, 2010, 11:56:10 pm »
Don't forget that the Japanese name of the game is Majestic Twelve.  You might find information with that name.
P.S.  I love that game!!
cyberduck16
« Reply #9 on: September 10, 2010, 05:36:13 am »
Well I've got the screen flipping now as I found the dip switch settings on a site. Could anyone tell me what is supposed to happen when I flick the power switch. At the mo it just turns off the screen. I know this because I can still here the sound effects. Was wondering if it was supposed to turn it all off?
cyberduck16
« Reply #10 on: September 15, 2010, 03:22:50 am »
Hi
Well got the table up and running. Well until last night there was a big spark from what I assume is the monitor power board and now the CRT no longer displays :cry:. Is there any way to replace the CRT or would I be better off turning it in to a mame table? Any help will be greatly appreciated
IG-88
« Reply #11 on: September 15, 2010, 08:12:34 am »
Sure you can replace the CRT but it will be expensive. You have some descisions to make. Do you want to restore the cab or mame it?
If you are going to get serious into this hobby now would be a good time to learn how to run a multimeter and a soldering iron. Repairing old CRT's seems to be what a majority of the repairs these old cabs take imho.
-HarumaN
cyberduck16
« Reply #12 on: September 15, 2010, 09:20:22 am »
I would much rather try and restore it. I have some soldering skills already as I do a lot of Pc repairs. Also i know a little about multimeters. Can u point me in the right direction as what to do next? I have no idea where to start
RayB
  • There's my post
    • RayB.com
« Reply #13 on: September 15, 2010, 01:44:07 pm »
The spark may just have been the flash of the fuse popping.
Replacing a monitor is not expensive if you are getting another used one. Try to get connected with other local collectors.
NO MORE!!
cyberduck16
« Reply #14 on: September 15, 2010, 01:47:46 pm »
Ok well getting another CRT won't be a problem. it's just fitting it in with all the other boards etc.
IG-88
« Reply #15 on: September 15, 2010, 07:49:10 pm »
I guess I should've said getting a NEW one would be expensive.  ;D  If it were me I would try fixing the old one first before going after a used one that may have probs of it's own.
Not sure what you meant by "it's just fitting it in with all the other boards etc." The monitor and all it's "boards" are surrounded and connected to a frame which just bolts into the cab. Pretty straight forward to unbolt it and pull it out of the cab.
Let me say too that I'm no expert on monitor repair. There are quite a few of them on these boards however. Even more over on the KLOV forums.
Do you know what kind of monitor you have? Have you looked on the monitor's pcb's to see if you can locate any burnt fuses or other componets? You are aware of the high voltage that these things can zap you with even with them being unplugged?
Check this out to see if it helps:
http://www.arcaderepairtips.com/2009/06/27/troubleshooting-monitors-with-michael/
-HarumaN
cyberduck16
« Reply #16 on: September 16, 2010, 04:31:32 am »
Thanks alot m8 that is a great help :). I think I have located the problem looks to be a component on the board underneath the monitor. Going to try and take it out tonight and find out for definate if it is a component. will post up some pictures later today hopefully.
RayB
  • There's my post
    • RayB.com
« Reply #17 on: September 16, 2010, 12:50:55 pm »
Look up how to discharge a monitor first!
NO MORE!!
cyberduck16
« Reply #18 on: September 16, 2010, 04:14:04 pm »
hi guys
managed to get the board out have included pictures. there appears to be a damaged resistor. could this be a possible cause of the problem?
could any one point me to a resistor that would replace this one as i cant see the colours to identify it.
