Author Topic: router noob, bit questions  (Read 4035 times)
2panther
  • Last login:January 19, 2014, 04:02:12 pm
« on: September 08, 2010, 09:53:32 am »
I've never used a router in my life and I was lucky enough that my brother is letting me borrow his to cut the slot for the t-molding but I had a few questions first. I searched and searched and ran across some people saying that different size slots were needed and honestly I just ended up more confused and unsure of exactly what I need to get this part of my build done right.
First, I have my side panels cut out and upon closer inspection I can see some wobbly cuts I made so I wanted to get both panels clamped together and run what I believe is called a flush cut bit along the outside of the panels to make sure I have an exact match. The problem being that I have never used a router and am not quite sure what bit I need to use and if I even have the correct bit or if I need to purchased one. Here is a picture of the bits my brother sent with the router.
Second, I'm using 3/4" MDF for my build and I see multiple 3-wing slot cut bits on t-molding.com's website, which one will I need for my build? I'd rather not be hot gluing the entire length of tmolding after buying the wrong bit if I can make sure I get the correct bit for my application.
2panther
Re: router noob, bit questions
« Reply #1 on: September 08, 2010, 03:27:25 pm »
I'm not quite sure what to do about the flush trim bit but for the slot cutter, I just ordered a Slot Cutter Complete Assembly with arbor and bearing for $16 with the following specs from MLCS
Width of Cutter - 1/16th"
Shank - 1/4"
Depth of Cut - 1/2"
TheMonk
  • Last login:November 01, 2010, 09:56:58 pm
« Reply #2 on: September 08, 2010, 04:33:02 pm »
Hey congrats on starting, I'll be starting my first cab soon myself!
Have a look at this page he dicusses the router bits in detail.
http://www.arcadecab.com/CabinetPlans2/CabinetPlans2_Tools.html
Here's a part about using the flush trim bit:
http://www.arcadecab.com/CabinetPlans2/CabinetPlans2_Cutting_Side_Two.html
I've seen some folks order the t-molding first then cut some slots in a test piece of wood to determine the bit size and depth. This might slow you down a little but if you're not sure it's probably best to get some t-molding from tmolding.com and test it out before doing the whole slot.
 http://www.t-molding.com
Hope that helps!
2panther
« Reply #3 on: September 13, 2010, 04:09:46 pm »
ok, I feel like an idiot but I've never used one of these before. How do I assemble the slot cutting bit to the arbor with the bearing? What is the order? It didn't come with any directions.
slot cutter> then washer> bearing> second washer> nut?
 :dunno
« Last Edit: September 13, 2010, 04:15:42 pm by 2panther »
justinjstark
  • Last login:May 14, 2021, 02:20:13 pm
« Reply #4 on: October 27, 2010, 12:35:55 pm »
 :dunno
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
From top to bottom: slot cutter, washer, bearing, washer, nut
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: October 27, 2010, 07:17:42 pm »
Also, at t-molding.com com you can order free samples (you just pay for shipping).  You can then measure using the samples.
Digital Vandal
  • Last login:December 19, 2010, 04:22:37 am
« Reply #6 on: October 31, 2010, 06:33:11 pm »
 :dunno
I can't find anything near their prices in the UK. Cheapest I've found is nearly £20 just for the cutting disk, then you have to buy the arbor and bearing on top! I'm wanting to build a Ultimate arcade II (or at least that's the only one I've found that will take a large tv and 4 player cp) and I am struggling greatly with finding the parts I need as everything is metric over here and all the plans and the tools are listed in imperial sizes and they just don't translate.  :banghead:
