Author Topic: Mame ROM set - How/Best way to verify all good/correct?  (Read 37223 times)
GameTech
  • Last login:July 31, 2016, 01:41:14 pm
« on: September 06, 2010, 10:13:41 pm »
I just got the entire mame .139 set, and was curious if there is a way to "verify" the roms, etc.. I think clrmamepro is a program that does this?  I just wanted to make sure the entire set was really a .139 and has all the correct rom names, etc, before I continue with a large cabinet build.
Thanks guys.
Greetings From The Lord Humongous!
  • Last login:July 11, 2025, 09:17:44 am
Re: Mame ROM set - How/Best way to verify all good/correct?
« Reply #1 on: September 07, 2010, 12:48:01 pm »
ClrMAME is the way to do it.  I believe you need to have a MAME.dat file for the current version you are using.  The dat file contains all the info CLrMAME needs and then it cross checks your roms.  :-)
You can find the dat files here:
http://www.logiqx.com/Dats/
D
GameTech
« Reply #2 on: September 08, 2010, 12:03:17 am »
Thanks Delus, I will check this out.
Roo
  • Last login:October 15, 2010, 09:17:03 pm
« Reply #3 on: September 08, 2010, 12:18:49 am »
I agree with Delusional, ClrMamePro is the way to go.
But it can be confusing when you first start using it, this may help:
http://retro-roms.blogspot.com/2010/01/clrmamepro-tutorial-part-3.html
Digital Vandal
  • Last login:December 19, 2010, 04:22:37 am
« Reply #4 on: October 16, 2010, 05:43:14 pm »
How do you upgrade the 0.136 set to 0.139 standard? (is there much difference?) or do you not bother?
