Author Topic: Changing Default Mame Controls  (Read 7373 times)
Xynie
  • Last login:July 13, 2020, 09:30:19 am
  • Sometimes, I feel like Dilbert.
« on: September 06, 2010, 08:47:37 am »
Silly question, but I can't seem to figure this out.  I want to permanently change a button assignment in Mame, but when I Tab and change the general key assignment it doesn't seem to work.  It works for that game, but as soon as I go back to my frontend and start another game, it reverts back to the default controls.
Is there a text file I can edit instead of using the tab screen?  I am running .138.
Hoopz
  • Last login:Yesterday at 06:24:57 am
  • Intellivision Rocks!
Re: Changing Default Mame Controls
« Reply #1 on: September 06, 2010, 08:50:57 am »
When in the Mame menu, are you changing the inputs for just that game or for all?  If you exit the game and then restart the same one, does the button keep it's configuration?
Xynie
« Reply #2 on: September 06, 2010, 09:28:24 am »
I've tried it both ways, and when I exit and re-enter the same game, it does not save the changes.  It works while I play the game, but as soon as I reload it reverts back.
Hoopz
« Reply #3 on: September 06, 2010, 09:45:36 am »
If you go into your mame directory, do you have a config folder? If so, do you have files in there?  Deleting anything in there may help.  I don't have Mame installed on this pc, so I can't easily check that right now.
The other guess is to make sure that the Mame folder or sub-directories and files are write protected. I don't know if that would affect things like this but it's something to check. If you're running XP, that could be the issue.   :dunno
Xynie
« Reply #4 on: September 06, 2010, 09:46:42 am »
Not sure if there should be one... but there is no default.cfg file in the ctrl directory, so i can't find anything to manually change settings.  Also, I just tested again, changes settings within a game... it worked in game... exited and restarted same game, controls revert.  Do I need to create a default.cfg?  Does frontend matter?  (Hyperspin)  Just making sure....
Xynie
« Reply #5 on: September 06, 2010, 09:47:50 am »
No CFG folder... although mame.ini does point to it <shrug>
Xynie
« Reply #6 on: September 06, 2010, 09:50:58 am »
Mame.ini.... if this helps.  Is there a setting I need to turn on to enable saving controls, like I had to enable the mouse? :)
Code: [Select]
<UNADORNED0>
# CORE CONFIGURATION OPTIONS
readconfig                1
# CORE SEARCH PATH OPTIONS
rompath                   roms
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
uimodekey                 auto
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
Hoopz
« Reply #7 on: September 06, 2010, 09:51:36 am »
More details please including:
Command line mame, Mame32 (or 64) and what Front End?
Computer OS?
Try a fresh install of Mame.  Don't delete anything, just install Mame again and point the directory to the proper Rom folder.
Hoopz
« Reply #8 on: September 06, 2010, 09:52:15 am »
And when you hit tab to enter the Menu, you aren't pausing the game first are you?  That causes problems.
Xynie
« Reply #9 on: September 06, 2010, 09:53:09 am »
Mame.ini above...
Mame64 .138 on XP 64-bit
Hyperspin
No pause... just straight to pressing tab.  This is a weird one... I have been using Mame for a long time, this is a first for me :)
Hoopz
« Reply #10 on: September 06, 2010, 09:54:36 am »
Mame.ini above...
Hyperspin
Well at least it isn't an easy one so far.   :)
Hoopz
« Reply #11 on: September 06, 2010, 09:55:37 am »
Do you have a cntrl file in the cntrl folder?
I wish u_rebelscum was here, he's aces at this stuff.  He was on today, but hasn't posted in about 6 months.   :'(
Xynie
« Reply #12 on: September 06, 2010, 09:57:31 am »
The contents of the cntrl folder are all named controllers, like slikstick and hotrod.  There is no default.cfg or cntrl.cfg
Thanks for your help :)
Hoopz
« Reply #13 on: September 06, 2010, 09:59:44 am »
I'm just jacking up my post count.  We get double counts on holidays.   ;D
Try reinstalling Mame though.  It shouldnt take too long and may help.
Hoopz
« Reply #14 on: September 06, 2010, 10:05:42 am »
Also, try launching a game outside of your FE.  I don't know anything about Hyperspin, but it could have a setting that doesn't accept your change.  Not blaming the FE, but it's one thing to try to rule it out.
So use the command line to run a game, change the input, exit it, and try again.
Xynie
« Reply #15 on: September 06, 2010, 10:08:06 am »
OK... downloaded .139, ran it completed seperate in a new, unconfigured install/directory through Hyperspin.  Same thing... let me try without hyperspin... To be continued!
Hoopz
« Reply #16 on: September 06, 2010, 10:09:38 am »
Is getting a dedicated for the game in question an option?   :laugh2:
Xynie
« Reply #17 on: September 06, 2010, 10:11:46 am »
Haha... well, it happens on all the games.  Long story short, I have a bad IPAC4 with mismapped ports.  Andy sent me a new one, but I am trying to get it to work for the holiday party as a two player.  It works, but it won't save the settings.
OK, so the plot thickens... I launched a game outside of hyperspin, changed the settings, relaunched...it worked.  Sounds like a hyperspin thing to me... Off to their forums :)  Thanks for all your help :)
Hoopz
« Reply #18 on: September 06, 2010, 10:14:02 am »
Oh, the Hyperspin haters are going to love this. j/k  Hopefully, you can make a simple change and have it work.   :cheers:
Do try and  post the findings here in case someone else searches for the same problem please.
Xynie
« Reply #19 on: September 06, 2010, 10:17:30 am »
I figured out a workaround... I turned off the "Hyperlaunch" feature in HyperHQ and launched Mame as a normal executable... that resolves the issue.
Thanks for helping me track it down.  I will head over to the Hyperlaunch forums to see if it is something I did, or something that doesn't work.
Thanks gain!
