Author Topic: No sound on new motherboard  (Read 2103 times)
danny_galaga
  • Last login:Today at 08:27:40 pm
    • dans cocktail lounge
danny_galaga
Re: No sound on new motherboard
« Reply #1 on: September 03, 2010, 08:47:59 pm »
This is the dxdiag thingo:
System Information
Time of this report: 9/4/2010, 07:59:07
       Machine name: EXPERIEN-A301C9
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
           Language: English (Regional Setting: English)
System Manufacturer: n/a
       System Model: n/a
               BIOS: n/a
          Processor: Intel(R) Atom(TM) CPU D510   @ 1.66GHz (4 CPUs)
             Memory: 1014MB RAM
          Page File: 88MB used, 2352MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
          Music Tab: No General MIDI DLS file was specified in the registry.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: Intel(R) Graphics Media Accelerator 3150
     Manufacturer: Intel Corporation
        Chip type: Intel(R) Graphics Media Accelerator 3150
         DAC type: Internal
       Device Key: Enum\PCI\VEN_8086&DEV_A001&SUBSYS_0D55105B&REV_02
   Display Memory: 256.0 MB
     Current Mode: 800 x 600 (32 bit) (60Hz)
          Monitor: Default Monitor
  Monitor Max Res:
      Driver Name: igxprd32.dll
   Driver Version: 6.14.0010.5106 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 8/19/2009 04:37:38, 57344 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: igxpmp32.sys
    Mini VDD Date: 8/19/2009 04:37:38, 6301696 bytes
Device Identifier: {D7B78E66-E341-11CF-1960-5F2DA3C2CB35}
        Vendor ID: 0x8086
        Device ID: 0xA001
        SubSys ID: 0x0D55105B
      Revision ID: 0x0002
      Revision ID: 0x0002
      Video Accel:
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Not Available
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description:
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID:
             Product ID:
                   Type:
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
DirectMusic
        DLS Path:
     DLS Version:
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27C9
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 23:15:38, 59520 bytes
| Driver: usbd.sys, 8/17/2001 14:03:02, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 00:48:02, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 00:09:48, 24576 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x0EC7, 0x0001
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 23:09:48, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: MS TCP Loopback interface - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
System Devices
     Name: Intel(R) Graphics Media Accelerator 3150
Device ID: PCI\VEN_8086&DEV_A001&SUBSYS_0D55105B&REV_02\3&11583659&0&10
   Driver: C:\WINDOWS\system32\DRIVERS\igxpmp32.sys, 6.14.0010.5106 (English), 8/19/2009 04:37:38, 6301696 bytes
   Driver: C:\WINDOWS\system32\igxprd32.dll, 6.14.0010.5106 (English), 8/19/2009 04:37:38, 57344 bytes
   Driver: C:\WINDOWS\system32\igxpgd32.dll, 6.14.0010.5106 (English), 8/19/2009 04:37:38, 185856 bytes
   Driver: C:\WINDOWS\system32\igxpdv32.dll, 6.14.0010.5106 (English), 8/19/2009 04:37:52, 2685920 bytes
   Driver: C:\WINDOWS\system32\igxpdx32.dll, 6.14.0010.5106 (English), 8/19/2009 04:37:48, 3773952 bytes
   Driver: C:\WINDOWS\system32\igxpxk32.vp, 8/19/2009 04:02:06, 2096 bytes
   Driver: C:\WINDOWS\system32\igxpxs32.vp, 8/19/2009 04:56:20, 32624 bytes
   Driver: C:\WINDOWS\system32\hccutils.dll, 6.14.0010.5106 (English), 8/19/2009 04:07:50, 93696 bytes
   Driver: C:\WINDOWS\system32\igfxsrvc.dll, 6.14.0010.5106 (English), 8/19/2009 04:08:14, 51712 bytes
   Driver: C:\WINDOWS\system32\igfxsrvc.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:56, 250392 bytes
   Driver: C:\WINDOWS\system32\igfxpph.dll, 6.14.0010.5106 (English), 8/19/2009 04:08:34, 199168 bytes
   Driver: C:\WINDOWS\system32\igfxcpl.cpl, 6.14.0010.5106 (English), 8/19/2009 04:08:48, 119296 bytes
   Driver: C:\WINDOWS\system32\igfxcfg.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:48, 652312 bytes
   Driver: C:\WINDOWS\system32\igfxdev.dll, 6.14.0010.5106 (English), 8/19/2009 04:07:44, 205312 bytes
   Driver: C:\WINDOWS\system32\igfxdo.dll, 6.14.0010.5106 (English), 8/19/2009 04:08:34, 130048 bytes
   Driver: C:\WINDOWS\system32\igfxtray.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:58, 141336 bytes
   Driver: C:\WINDOWS\system32\hkcmd.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:46, 173592 bytes
   Driver: C:\WINDOWS\system32\igfxress.dll, 6.14.0010.5106 (English), 8/19/2009 04:07:32, 5702656 bytes
   Driver: C:\WINDOWS\system32\igfxpers.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:54, 141336 bytes
   Driver: C:\WINDOWS\system32\igfxrara.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:52, 252416 bytes
   Driver: C:\WINDOWS\system32\igfxrchs.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:54, 178176 bytes
   Driver: C:\WINDOWS\system32\igfxrcht.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:54, 179712 bytes
   Driver: C:\WINDOWS\system32\igfxrdan.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:54, 280576 bytes
   Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:54, 303616 bytes
   Driver: C:\WINDOWS\system32\igfxrenu.lrc, 6.14.0010.5106 (English), 8/19/2009 04:07:32, 275968 bytes
   Driver: C:\WINDOWS\system32\igfxresp.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:56, 303104 bytes
   Driver: C:\WINDOWS\system32\igfxrfin.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:56, 281088 bytes
   Driver: C:\WINDOWS\system32\igfxrfra.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:56, 303104 bytes
   Driver: C:\WINDOWS\system32\igfxrheb.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:58, 249856 bytes
   Driver: C:\WINDOWS\system32\igfxrita.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:58, 304640 bytes
   Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:58, 206848 bytes
   Driver: C:\WINDOWS\system32\igfxrkor.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:00, 205312 bytes
   Driver: C:\WINDOWS\system32\igfxrnld.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:00, 299008 bytes
   Driver: C:\WINDOWS\system32\igfxrnor.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:00, 279552 bytes
   Driver: C:\WINDOWS\system32\igfxrplk.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:00, 287744 bytes
   Driver: C:\WINDOWS\system32\igfxrptb.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:02, 289280 bytes
   Driver: C:\WINDOWS\system32\igfxrptg.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:02, 294912 bytes
   Driver: C:\WINDOWS\system32\igfxrrus.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:02, 291328 bytes
   Driver: C:\WINDOWS\system32\igfxrsky.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:02, 282624 bytes
   Driver: C:\WINDOWS\system32\igfxrslv.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:04, 277504 bytes
   Driver: C:\WINDOWS\system32\igfxrsve.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:04, 282624 bytes
   Driver: C:\WINDOWS\system32\igfxrtha.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:04, 262656 bytes
   Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:54, 282624 bytes
   Driver: C:\WINDOWS\system32\igfxrell.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:56, 310784 bytes
   Driver: C:\WINDOWS\system32\igfxrhun.lrc, 6.14.0010.5106 (English), 8/19/2009 04:10:58, 288256 bytes
   Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 6.14.0010.5106 (English), 8/19/2009 04:11:04, 279040 bytes
   Driver: C:\WINDOWS\system32\igfxext.exe, 6.14.0010.5106 (English), 9/1/2009 22:07:50, 172056 bytes
   Driver: C:\WINDOWS\system32\igfxexps.dll, 6.14.0010.5106 (English), 8/19/2009 04:08:50, 23552 bytes
   Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.5106 (English), 8/19/2009 04:26:18, 2342912 bytes
   Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.5106 (English), 8/19/2009 04:26:28, 294912 bytes
   Driver: C:\WINDOWS\system32\igfxCoIn_v5106.dll, 1.01.0017.0000 (English), 8/19/2009 04:43:52, 155648 bytes
     Name: Intel(R) N10 Family DMI Bridge - A000
Device ID: PCI\VEN_8086&DEV_A000&SUBSYS_00000000&REV_02\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) N10/ICH7 Family SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_0D55105B&REV_02\3&11583659&0&FB
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_0D55105B&REV_02\3&11583659&0&D8
   Driver: n/a
     Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_00000000&REV_02\3&11583659&0&E1
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 23:06:46, 68224 bytes
     Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_02\3&11583659&0&E0
     Name: Intel(R) N10/ICH7 Family USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_0D55105B&REV_02\3&11583659&0&EF
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 23:15:36, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 23:15:38, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 04:42:10, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 23:15:38, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 05:41:56, 7168 bytes
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_0D55105B&REV_02\3&11583659&0&EB
   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 23:15:36, 20608 bytes
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_0D55105B&REV_02\3&11583659&0&EA
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_0D55105B&REV_02\3&11583659&0&E9
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_0D55105B&REV_02\3&11583659&0&E8
     Name: Intel(R) N10/ICH7 Family Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_0D55105B&REV_02\3&11583659&0&FA
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 12:51:52, 3328 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 23:10:30, 24960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 23:10:32, 96512 bytes
     Name: Intel(R) NM10 Family LPC Interface Controller - 27BC
Device ID: PCI\VEN_8086&DEV_27BC&SUBSYS_00000000&REV_02\3&11583659&0&F8
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_E2\3&11583659&0&F0
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_0D55105B&REV_03\4&23C6FC68&0&00E1
   Driver: n/a
danny_galaga
« Reply #2 on: September 03, 2010, 08:48:25 pm »
DirectX Components
   ddraw.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 279552 bytes
 ddrawex.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 1179648 bytes
 d3d8thk.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 824320 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 5/6/2008 13:00:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 5/6/2008 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 17920 bytes
   dpnet.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 3072 bytes
 dpnaddr.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 3072 bytes
 dpvoice.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 83456 bytes
  dpvvox.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 116736 bytes
  dpvacm.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 5/6/2008 13:00:00 53520 bytes
  dinput.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 158720 bytes
 dinput8.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 394240 bytes
     joy.cpl: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 5/6/2008 13:00:00 76800 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 35328 bytes
  dsound.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 71680 bytes
  dmusic.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 35840 bytes
 dmstyle.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 105984 bytes
 dmsynth.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 82432 bytes
   dx7vb.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 619008 bytes
   dx8vb.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 1227264 bytes
 dxdiagn.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 5/6/2008 13:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 5/6/2008 13:00:00 1028096 bytes
 wsock32.dll: 5.01.2600.5512 English Final Retail 5/6/2008 13:00:00 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 70656 bytes
 devenum.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 5/6/2008 13:00:00 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 35328 bytes
 mpg2splt.ax: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 20480 bytes
    qasf.dll: 9.00.0000.4503 English Final Retail 5/6/2008 13:00:00 237568 bytes
    qcap.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 192512 bytes
     qdv.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 279040 bytes
    qdvd.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 386048 bytes
   qedit.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 733696 bytes
  quartz.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 1288192 bytes
 strmdll.dll: 4.01.0000.3936 English Final Retail 5/6/2008 13:00:00 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 5/6/2008 13:00:00 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 5/6/2008 13:00:00 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 5/6/2008 13:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 5/6/2008 13:00:00 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 5/6/2008 13:00:00 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 5/6/2008 13:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 5/6/2008 13:00:00 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 5/6/2008 13:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 203776 bytes
      ks.sys: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 141056 bytes
  stream.sys: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 49408 bytes
  swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 5/6/2008 13:00:00 118272 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 30208 bytes
   msyuv.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 5/6/2008 13:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1133
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5512
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1133
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Video Compressors:
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
danny_galaga
« Reply #3 on: September 03, 2010, 08:51:03 pm »
Now, I realise almost straight away it says 'Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.'
But I've installed and reinstalled the drivers in several different ways. It's supposed to have onboard sound...
A friend suggested there might be a jumper on the motherboard. I couldn't see one where I stood. I might just pull it out and have a good look...
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #4 on: September 03, 2010, 09:13:02 pm »
Is on-board sound enabled in the bios?
Is anything showing up for sound in the Device Manager?
manual integrated peripherals p28/29.
latest drivers, etc, there too?
« Last Edit: September 03, 2010, 09:30:36 pm by EwJ »
abispac
  • Last login:Yesterday at 01:12:34 am
« Reply #5 on: September 03, 2010, 09:51:43 pm »
google for "everest portable" or get a trial version, once you get that run it and it will tell you what the soundcard its and the exact driver you need...
danny_galaga
« Reply #6 on: September 04, 2010, 09:21:36 am »
I suspect that I'm never going to solve this. But some guys have out me onto using a two dollar USB sound thingo, so i've made the outlay and I'll see how tnat works out  :D
abispac
« Reply #7 on: September 04, 2010, 12:54:35 pm »
if its a new motherboard, you shouldnt need a onother audio card, the one on the board works just fine, now if you ask for help and decide to trow the towel in the way, then dont ask for help, as i believe its just a matter to toubleshoot your problem, it could be that the driver its incorrect,or you have to mess with the jumpers on the motherboard, simple stuff, like John Cena says  :laugh2: DONT GIVE UP  :laugh2: ewj asked you if there was somenthing show in the device manager and you did not answer that question, that would help us alot to help you solve the issue....
danny_galaga
« Reply #8 on: September 04, 2010, 08:53:34 pm »
Sorry, what isn't apparent here is that I posed the question on three different forums, so I've been working through the various advice given on all three. It might seem I've prematurely given up, but a lot of hair  pulling has been done!
I've also contacted the guy who sold me the motherboard, and am waiting on a response. It could be something he has come across before.
I ordered the USB thingo so that if I can't figure it out (which I doubt I will now) then at least there will be some way of getting sound. believe me, I hate the idea of having to do it. I bought a brand new motherboard with onboard sound so i wouldn't have any problems!
abispac
« Reply #9 on: September 04, 2010, 10:39:06 pm »
good luck, i remember i had a couple of similar problems with sound, and as you said, i too pull out my hair so much , but at the end things worked out well,  :cheers:
