Author Topic: Coin Door Insert Image  (Read 3746 times)
SirPeale
  • Green Mountain Man
« on: August 08, 2003, 12:30:08 pm »
I'm looking to use Wal-Mart's digital photo printing services to print out some new coin reject inserts.
I've attached one of the images I'd like to use.  AFAIK, it's to scale.
Wal-Mart told me their machine outputs @ 900 DPI.  However, I'm sure that their software will try to scale the image to fit their scale.  This image is 801x1902, and I think that it'll rescale based on resolution of 640x480 (and up, 800x600, 1024x768 and up are the same scale)
How can I make sure I get an image (printed on 3x5 stock) that's going to be the correct size?  I tried doing this with just one slot, and they blew it up to 3x5 (it should be less than 1x1) and turned it green!
helios
  • Last login:September 08, 2005, 03:42:27 am
  • I'm a Moose!
Re:Coin Door Insert Image
« Reply #1 on: August 08, 2003, 01:27:53 pm »
Do you have photoshop? If so, try creating a 3x5 in. image @ 900 dpi, and then create the coin door insert on a 1024x768 doc. Drag the finished coin door onto the 3x5, and save.
If Wal-Mart resizes down to 1024x768, and then streches to 3x5, this should work fine. Just a suggestion...
« Last Edit: August 08, 2003, 01:35:16 pm by helios »
SirPeale
« Reply #2 on: August 08, 2003, 01:36:18 pm »
Do you have photoshop? If so, try creating a 3x5 in. image @ ?? dpi, and the drag the coin insert image onto the 3x5. Resize the coin image to scale (on the 3x5) and then it should print out fine.
Does Wal-Mart allow you to change the dpi that it prints at, or does it have a preset one? You need to know so that you can set the dpi on the 3x5 image correctly. Hopefully that will work--just a suggestion.
No Photoshop, just an old copy of Paint Shop Pro.  Hey, it works (so far) for everything I want it to do!
The only thing I can't do is delegate size of image.  I can do it by pixel, but not by inches.
AFAIK, it's a preset DPI.
helios
  • I'm a Moose!
« Reply #3 on: August 08, 2003, 03:11:35 pm »
3x5 inches in pixels @ 900dpi is 2700x4500.
Try that out and see if it works.
SirPeale
« Reply #4 on: August 08, 2003, 03:42:43 pm »
I know the coversion.  But if I copy/paste the coin image into this new 2700x4500 image, it's teeny tiny in comparison.
Besides, you can print 640x480 3x5 prints at Wal-Mart with no problems.  It's when you blow them to 8x10 that they start getting grainy.
helios
  • I'm a Moose!
« Reply #5 on: August 08, 2003, 03:58:24 pm »
Ahhhh--- I'm seeing where your predicament is. If the image isn't large enough for the hi-res, then it's gonna show up small. The graphic looks fairly simple, have you though about just making it vector? That would solve all your problems.
« Last Edit: August 08, 2003, 03:58:47 pm by helios »
SirPeale
« Reply #6 on: August 08, 2003, 04:28:02 pm »
If I had a vector program, I might.  * SIGH * it sucks being poor.
helios
  • I'm a Moose!
« Reply #7 on: August 08, 2003, 05:58:01 pm »
You might wanna try d/l the demo of say, Flash MX, and then you have a fully functional vector prog for 30 days. I would reccomend Illustrator, but I don't know the what kind of restrictions the demo puts on you. With a demo anyways you have long enough to learn the prog and make what you need to....
SirPeale
« Reply #8 on: August 08, 2003, 08:28:29 pm »
I might give it a shot, but there's still got to be a way to do this correctly.
I was thinking perhaps if I take a regular photo, resize it to 640x480, I could just cut -n- paste the images in there.  It would have the correct pallete, correct dimensions, and since I'd have to cut them out anyway, supposedly no problems.  In theory.
