Author Topic: r-82 rowe jukebox  (Read 3003 times)
jlmoulde
  • Newbie
  • Last login:September 03, 2010, 02:09:49 pm
r-82 rowe jukebox
« on: September 01, 2010, 01:22:08 pm »
I have r-82 rowe jukebox the transfer is not working all the light are working i do have a manual can someone point me in the right direction
Havok
  • Trade Count: (+17)
Re: r-82 rowe jukebox
« Reply #1 on: September 01, 2010, 04:14:49 pm »
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: September 02, 2010, 07:27:36 am »
Hello,
Have you checked that the power supply voltages are ok and that all of the led,s are lit?
Rowe Ami jukeboxes are prone to dry joints (cold joints in the USA) on all of the electronic boards and amplifiers.
I suggest that you start with  the power supply
and then check out the Mechanism Control, Memory Unit and Selector logic boards.
Concentrate on the connection pins, but have a look for at the rest of the soldering for problems.
If checking and rectification of the above does not sort your problems then you need to send the above boards to a Rowe Ami specialist. I do this work in the UK.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
