Author Topic: Joystick mounting  (Read 1407 times)
TheGameAh
  • Last login:June 09, 2004, 10:52:01 am
  • You are not FreakZilla.
    • Arcade Cab
Joystick mounting
« on: August 08, 2003, 11:02:48 am »
Hey guys, simple question.  I'm swinging by Ace Hardware after work to pick up hopefully some countersunk bolts to mount a joystick.  What is the common size for a bolt if you're trying get a countersunk bolt or screw so contact paper hides it?
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
Re:Joystick mounting
« Reply #1 on: August 08, 2003, 10:47:27 pm »
Screw the joys in from the bottom of the CP.  That way it's not a pain in the...um...rear..yea...to change/replace you joys if you ever need/want to.  Just my opinion.  ;)
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #2 on: August 09, 2003, 12:03:50 am »
I second the motion to screw the joys in from the bottom of the CP.  I did mine that way and haven't had any problems.  Alot of people on here disagree with this type of mounting, but there are those of us who've had great success doing it this way.  I think its all about drilling a pilot hole and using large thread screws.  I personally used of all things Metal screws(not to be confused with machine thread screws).  #12 x 3/4" hex washer head zinc screws to exact.  These are quite beefy and have held quite well for me.  I feel certain that the joystick base will break before one of these lets loose.  Of course, you'll most likely feel the need to route a recess if you mount the joys from the bottom.  Otherwise the joys will be rather stuby in height.  Some people don't mind, i think most like a little extra height. I routed close to a 1/4" recesss for mine i believe.  So far i've been quite happy with the way its worked out.  Just my 2 cents.
-Kevin
« Last Edit: August 09, 2003, 12:05:45 am by Homebrew »
