Author Topic: Can Novus polish be used on polyurethane?  (Read 2878 times)
  • Last login:Yesterday at 12:10:15 pm
« on: August 27, 2010, 07:35:30 pm »
I've got a finished piece of wood I want to make even smoother.  Will it work?
Q*Bert_OP
  • Oh yes, we did!
Re: Can Novus polish be used on polyurethane?
« Reply #1 on: August 27, 2010, 07:50:06 pm »
Try it on a hidden area. You want to cut some texture down? You may have best results with a random orbital buffer.
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #2 on: August 27, 2010, 09:20:43 pm »
I've always used multiple coats of poly and then ultra fine steel wool.
« Reply #3 on: August 31, 2010, 05:23:18 pm »
Is the steel wool the last step or do you always put one last coat of poly on top?
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
« Reply #4 on: August 31, 2010, 05:40:28 pm »
Is the desired result to also have a less glossy finish? That's typical of using #0000 steel wool towards the end of the process.
If you want ridiculously flat, deep, high gloss finish, you might find this article helpful*:
http://ironvulva.com/temp/fwwHiGloss.pdf
*I kind of find that to be overkill,though... I'm always happy with the look of General Finishes Arm-R-Seal padded on over several thin coats (as a top coat for their Seal-A-Cell).
« Last Edit: August 31, 2010, 05:51:43 pm by MikeDeuce »
