Author Topic: PSX iso issues with epsxe (multiple .bin files)  (Read 21399 times)
jimmy2x2x
« on: August 26, 2010, 04:56:32 pm »
Im having an issue with games with multiple .bin files
For example, Ridge racer has 14 .bin files and 1 .cue file.
If I open the .cue with epsxe, I get an error opening the .iso
So I tried mounting the .cue with daemon tools and running a CDROM from espxe
The game runs, but with no CDDA audio.
The same thing happens with WipeoutXL (same disc structure, same issues)
Another oddity I have is Rtype Delta - the game runs great, and the attract mode works
But when I press start to start a game, I can navigate the menu up and down - but cant select anything!
Everything seems to be configured correctly, im running Gradius Gaiden, Dead or Alive, Einhander, Gauntlet Legends, Philosoma and Tekken 3 without any issues.
All games sourced from UG [Redump.org] Sony - PlayStation (NTSC-U) 20100722, so they should be solid.
« Last Edit: August 26, 2010, 09:28:13 pm by jimmy2x2x »
WhereEaglesDare
    • My HomePage
Re: PSX iso issues with epsxe (multiple .bin files)
« Reply #1 on: August 26, 2010, 11:16:38 pm »
did you rip this?  you should try to download a fresh copy from a different site
jimmy2x2x
« Reply #2 on: August 26, 2010, 11:42:15 pm »
The data is fine, Ive managed to get both the games working.
Used moobys cdrom plug in, turn up the cdda volume in the plug in settings the run CDROM rather ISO
Its a bit fiddly and doesnt seem super stable to me, I was hoping to have wipeout and ridgeracer playable from a front end - I might have to look into starting those as batch files.
No idea why I cant select anything from the menu in Rtype Delta - that is a really odd problem!
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: August 27, 2010, 09:57:03 am »
Have you tried the emulator simply named PSX? I never have problems with it. (And R-type Delta runs perfect in it)
jimmy2x2x
« Reply #4 on: August 27, 2010, 10:06:18 am »
got an URL for that?
PSX emulator throws up a lot of results.
Ginsu Victim
« Reply #5 on: August 27, 2010, 10:14:52 am »
I'm sure it does. :lol
http://www.zophar.net/psx/psx.html
jimmy2x2x
« Reply #6 on: August 27, 2010, 10:38:17 am »
That looks great, do you know how to start the emu full screen?
EDIT: -f seems to do it
Cheers for that, everything seems to be working fine now
« Last Edit: August 27, 2010, 10:48:37 am by jimmy2x2x »
Ginsu Victim
« Reply #7 on: August 27, 2010, 11:06:41 am »
Awesome. Glad it worked for you.
